current sheet revision field block update with another block fielded attribute
mduvalAA6EJ
Message 1 of 20
mduvalAA6EJ
hello I created a block attachment containing attributes (32) of "1 to 8" (8 rows 4 columns) + "0" (4) (1 row 4 columns)
 linked to fields, I would like to create a lisp which selects the values ​​of the columns of the last filled row (revision) to transpose it to the attributes of row 0 "current sheet"field, and updated automatically..is it possible to do this with lisp programming? thank you very much
Replies (19)
Message 2 of 20
ВeekeeCZ
@mduvalAA6EJ wrote:
hello I created a block attachment containing attributes (32) of "1 to 8" (8 rows 4 columns) + "0" (4) (1 row 4 columns) linked to fields, I would like to create a lisp which selects the values ​​of the columns of the last filled row (revision) to transpose it to the attributes of row 0 "current sheet"field, and updated automatically..is it possible to do this with lisp programming? thank you very much
Posted to better readability.
Message 3 of 20
mduvalAA6EJ
here is the dwg to understand what i am trying to do
work with the sheets and insert a table with the sheet list as well as their last revision
Message 4 of 20
mduvalAA6EJ
what I want is that the lisp takes the last value entered in the attributes between row 1 to 8 and put it in the fields of row 0 ... example if there is something registered in row 1 and that we add data in the field row 2, it is the row 2 which is registered in the field 0 ... the field 1 to 8 will be modified from the ssm and the field 0 will be automatically modified by the lisp, ideally a function that performs the task without me having to open each drawing and run it ...
Message 5 of 20
mduvalAA6EJ
ca pourrait aussi etre l'inverse lorsque je change la valeur des field de la rangée 0 avec le ssm ceal ajoute une ligne d'attribut ou de field (de 1 @ 😎 pour chaque changement...
Message 6 of 20
patrick.emin
Hello @mduvalAA6EJ can you keep the discussion in English please?
Patrick Emin animateur de la communauté francophone
Vous avez trouvé un message utile? Alors donnez un "J'aime" à ce message!
Votre question a eu une réponse satisfaisante? Voulez vous avoir l'amabilité de cliquer sur le bouton
 APPROUVER LA SOLUTION  en bas de la réponse qui apporte une solution?
Signez notre Livre d'Or
Message 7 of 20
mduvalAA6EJ
i can translate with this option ... do you can?
Message 8 of 20
mduvalAA6EJ
it could also be the other way around when I change the field value of row 0 with the ssm ceal adds an attribute or field row (from 1 @ 😎 for each change ...
Message 9 of 20
mduvalAA6EJ
the row 1 to 8 or more can be diesel expression value of  field row 0 when it change only.... see diesel expression change https://knowledge.autodesk.com/support/autocad-lt/learn-explore/caas/CloudHelp/cloudhelp/2019/ENU/Au...
Message 10 of 20
mduvalAA6EJ
sorry I'm not very used to the forum but this could be an example we have the field A in the sheet set manager (SSM) it is copied in the attributes 0, the attribute 0 creates a line 1 ... if we change A so it is no longer equal to 0 so create a line 2 etc
Message 11 of 20
mduvalAA6EJ
exemple we have variable
a ; SSM FIELD
0 ; LAST SSM FIELD WAS MADE
1 ; LAST 0 VALUE CHANGE #1
2 ; LAST 0 VALUE CHANGE #2
...TO 8 or more
first A= ###
if A change write value of a to 0... if 0 change write value of 0 change to 1 if 1 change write value of 1 to 2;; .. etc
i think the best way is the change on attribute 0 to 8 are diesel automate function
to do this is "if not equal"
and diesel ad line 1 to 8 one at time by change (exemple) but it can be more
the line a and 0 to 8 information is
rev number - date - description - by
0 is not printed but it can view on dwg file
1 to 8 is like on a revision table draw in the dwg file
A is a SSM field
A can be use to insert table projetct drawing and revison on main sheet
excuse my english
Message 12 of 20
mduvalAA6EJ
does someone can help me with this? excuse my english
;;; 2021-nov-03 by Martin Duval from Rochon experts Infrastructel
;;; revision sheet lisp for autocad
;;; REC_REVISION
;; dwg document property add this to this lisp work...
;CurrentSheetRevisionBy
;00SheetRevisionNumber
;00SheetRevisionDate
;00SheetIssuePurpose
;00SheetRevisionBy
;01SheetRevisionNumber
;01SheetRevisionDate
;01SheetIssuePurpose
;01SheetRevisionBy
;02SheetRevisionNumber
;02SheetRevisionDate
;02SheetIssuePurpose
;02SheetRevisionBy
(defun c:rec_revision
(vl-load-com)
(setq dwgrevARN (vlax-get-Property dProps 'RevisionNumber))
(setq dwgrevARD (vlax-get-Property dProps 'RevisionDate))
(setq dwgrevAIP (vlax-get-Property dProps 'IssuePurpose))
(setq dwgrevBY (vlax-get-Property dProps 'CurrentSheetRevisionBy))
(setq dwgrev00RN (vlax-get-Property dProps '00SheetRevisionNumber))
(setq dwgrev00RD (vlax-get-Property dProps '00SheetRevisionDate))
(setq dwgrev00IP (vlax-get-Property dProps '00SheetIssuePurpose))
(setq dwgrev00BY (vlax-get-Property dProps '00SheetRevisionBy))
(setq dwgrev01RN (vlax-get-Property dProps '01SheetRevisionNumber))
(setq dwgrev01RD (vlax-get-Property dProps '01SheetRevisionDate))
(setq dwgrev01IP (vlax-get-Property dProps '01SheetIssuePurpose))
(setq dwgrev01BY (vlax-get-Property dProps '01SheetRevisionBy))
(setq dwgrev02RN (vlax-get-Property dProps '02SheetRevisionNumber))
(setq dwgrev02RD (vlax-get-Property dProps '02SheetRevisionDate))
(setq dwgrev02IP (vlax-get-Property dProps '02SheetIssuePurpose))
(setq dwgrev02BY (vlax-get-Property dProps '02SheetRevisionBy))
(cond
( (=/ dwgrev00RN dwgrevARN)
(setq (vlax-get-Property dProps '00SheetRevisionNumber) dwgrev00RN)
(setq 0 DWGREV)
( (=/ dwgrev01RN dwgrev00RN) (= 0 REV)
(setq (vlax-get-Property dProps '00SheetRevisionNumber) dwgrev01RN)
(setq 1 DWGREV)
( (=/ dwgrev02RN dwgrev01RN) (= 1 REV)
(setq 2 DWGREV)
(princ)
Message 13 of 20
mduvalAA6EJ
this is a revision of my routine.... i hope someone help me with that...
;;; REC_REVISION
;; dwg document property (DWGPROP) add this to this lisp work...
;00SheetRevisionBy
;01SheetRevisionBy
;02SheetRevisionBy
(vl-load-com)
(setq dwgrevRN (vlax-get-Property dProps 'RevisionNumber))
(setq dwgrevRD (vlax-get-Property dProps 'RevisionDate))
(setq dwgrevIP (vlax-get-Property dProps 'IssuePurpose))
(setq dwgrevBY (vlax-get-Property dProps 'CustomCurrentSheetRevisionBy))
(setq dwgrev00RN (vlax-get-Property dProps 'Custom00SheetRevisionNumber))
(setq dwgrev00RD (vlax-get-Property dProps 'Custom00SheetRevisionDate))
(setq dwgrev00IP (vlax-get-Property dProps 'Custom00SheetIssuePurpose))
(setq dwgrev00BY (vlax-get-Property dProps 'Custom00SheetRevisionBy))
(setq dwgrev01RN (vlax-get-Property dProps 'Custom01SheetRevisionNumber))
(setq dwgrev01RD (vlax-get-Property dProps 'Custom01SheetRevisionDate))
(setq dwgrev01IP (vlax-get-Property dProps 'Custom01SheetIssuePurpose))
(setq dwgrev01BY (vlax-get-Property dProps 'Custom01SheetRevisionBy))
(setq dwgrev02RN (vlax-get-Property dProps 'Custom02SheetRevisionNumber))
(setq dwgrev02RD (vlax-get-Property dProps 'Custom02SheetRevisionDate))
(setq dwgrev02IP (vlax-get-Property dProps 'Custom02SheetIssuePurpose))
(setq dwgrev02BY (vlax-get-Property dProps 'Custom02SheetRevisionBy))
(setq 100 REVRN)
(setq 100 REVRD)
(setq 100 REVIP)
(setq 100 REVBY)
(cond
(/= dwgrev00RN dwgrevRN)
(setq (vlax-get-Property dProps 'Custom00SheetRevisionNumber) dwgrevRN)
(setq 0 REVRN)
(if
(and
(/= dwgrev01RN dwgrev00RN)
(= 0 REVRN)
(setq (vlax-get-Property dProps 'Custom01SheetRevisionNumber) dwgrevRN)
(setq 1 REVRN)
(if
(and
(/= dwgrev02RN dwgrev01RN)
(= 1 REVRN)
(setq (vlax-get-Property dProps 'Custom02SheetRevisionNumber) dwgrevRN)
(setq 2 REVRN)
(princ)
Message 14 of 20
pbejse
What you're asking is fairly easy ( I think 🙂 ).
Its just confusing. Can you post a drawing file showing before and after?
And whats with this?
 Appears to be missing a variable name?
Message 15 of 20
mduvalAA6EJ
heres the files ... (work with the same folder or reorganise it)
excuse my english
thank you very much!
Message 16 of 20
mduvalAA6EJ
I use "DWGPROP" to créate field and manipulate with ssm and lisp function "rec_revision" i dont know if they are a sample better way to do this like name the object on revision issue, but i think that coul be working fine...
to update the dwg in each issue i think i could run script that open each drawing and run rec_revison on each or use a diesel macro to do run it in dwg but i dont know now how to do this its ...
Message 17 of 20
mduvalAA6EJ
here a new version of rec_revision
there is a bug, I don't know how to find the exact name of the fields I want to put in the function
Message 18 of 20
mduvalAA6EJ
new revision
Message 19 of 20
mduvalAA6EJ
error message "too few argument" but i think that coulb working .. someone help me :)?
use this file i post before... and excuse my english
2021-11-05.dst
m101 test.dwg
REC_templateSS-2021-nov-05.dwt
Message 20 of 20
mduvalAA6EJ
new version of rec_revision (2021-nov-08 - 2)
2021-11-05.dst
m101 test.dwg
