save new file to pre-determined location but with new name
eharrisonTZS2M
eharrisonTZS2M
i have the following LISP to create a DXF, but the problem is, this LISP runs on whatever the file name is, regardless if it is saved or not. in a perfect world, my file would be saved, and i can get the proper location if my file is already saved. but what i'm wanting to do is to copy my object to a new drawing and run this lisp to create it as a dxf, but i want it to ask me what to name the file, so what do i replace ------ (substr (getvar 'dwgname) 1 (- (strlen (getvar 'dwgname)) 4))------ with to be able to customize the file name each time i run my LISP? I'd rather not change the LISP code if at all possible, just this particular section.
(defun c:DXF ( / fileName)
(vl-load-com)
  (vlax-for layout (vla-get-layouts
    (vla-get-ActiveDocument (vlax-get-acad-object))
       (if (/= (vla-get-name layout) "Model")
         (vla-delete layout)
        (command "._change" "all" "" "properties" "layer" "0" "")
        (command "._-purge" "all" "" "no")
(vla-saveas
   (vla-get-activedocument (vlax-get-acad-object))
   (strcat "F:\\mazak -NEO\\" (substr (getvar 'dwgname) 1 (- (strlen (getvar 'dwgname)) 4)) ".dxf")
   ac2000_dxf)
 (princ)
paullimapa
If you want to learn a bit of Autolisp specifically the getfiled function to allow you to enter a new file name at a specific folder location with Dxf extension then you can read up on it here
http://autolisp-kishore.blogspot.com/2013/06/getfiled-function-in-autolisp_1315.html?m=1
Paul Li
IT Specialist
@The Office
