Save ATTOUT-file to a specific location whith fixed name
djurk_haas
Message 1 of 1
djurk_haas
I adjusted the ATTOUT.LSP (see attachment) from AutoCAD (writes a xls-file instead of the standard txt-file).
What I would like to accomplish is to save the export file (xls) directly with a specific (fixed) filename.
The filename is eg TEST.
I also would like to add a specific location (path) where the xls-file must be saved instead of the location where the drawing is located.
Thanks (again) for the help.
Replies (0)
