Polyline with two points with stretch from one end and trim from the other
Hi.
I am looking for two lisps actually.
1. Draw two polylines by selecting two points 'A' and 'B'. These polylines have same length but mirrored from the center of two points and spaced a certain distance apart, say 400mm. The polylines are stretched 75mm from point A and trimmed 0.15*dist. between two points.
2. Draw three polylines by selecting three points 'A', 'B' and 'C' having a certain distance and certain length from the 2nd point. All three polylines must be centered between Point 'B' and point 'C'. For example, the length of longest polyline is (0.3*L + dist. between point 'B' and point 'C' + 0.3*L) The situation is illustrated in the figure.
I thank you in advance to all of you who would take some time to help me in this. Hats off to you!
Moshe-A
@Anonymous  hi,
here is my version
enjoy
moshe
(defun c:lisp1 (/ p0 p1 t0 t1 i)
 (if (and
       (setq p0 (getpoint "\nSpecify point A: "))
       (setq p1 (getpoint p0 "\nSpecify point B: "))
  (progn
   (setq i 0 t0 p0 t1 p1)
   (repeat 2
    (setq t0 (list (car t0) (+ (cadr t0) (* i 400.0))))
    (setq t1 (list (car t1) (+ (cadr t1) (* i 400.0))))
    (command "._line"
"_none" (polar t0 (angle t1 t0) 75.0) "_none" (polar t1 (angle t1 t0) (* (distance p0 p1) 0.15)) "") (setq i (1+ i) t0 p1 t1 p0) ) ); progn ); if (princ) ) (defun c:lisp2 (/ p0 p1 p2 p3 p4 cap len i) (if (and (setq p0 (getpoint "\nSpecify point A: ")) (setq p1 (getpoint p0 "\nSpacify point B: ")) (setq p2 (getpoint p0 "\nSpecify point C: ")) ) (progn (setq cap (distance p1 p2)) (setq len (distance p0 p1)) (setq p3 (polar p1 (angle p1 p2) (/ (distance p1 p2) 2))) (setq i 1) (foreach edge '(0.22 0.20 0.30) (setq p4 (polar p3 (/ pi 2) (* i 400.0))) (command "._line" "_none" (polar p4 (angle p0 p1) (+ (/ cap 2) (* len edge))) "_none" (polar p4 (angle p1 p0) (+ (/ cap 2) (* len edge))) "") (setq i (1+ i)) ); foreach ); progn ); if (princ) )
Thank you so much! Works perfectly. You have saved a lot of my time now. Thanks once again Smiley Happy
Hey thank you once again. The program runs perfectly in horizontal direction. But, when I try to draw vertically, it doesn't give the exact lines. I'm sorry I don't have any knowledge of LISP, so I don't know how to edit it. Cheers!
Moshe-A
fixed
(defun ma:qang (a)
 (cond
  ((or
    (equal a 0.0 1e-3)
    (equal a pi 1e-4)
    (equal a (* pi 2) 1e-3)
   (/ pi 2)
  ((or
    (equal a (/ pi 2) 1e-3)
    (equal a (* pi 1.5) 1e-3)
   pi
 ); cond
); qang
(defun c:lisp1 (/ p0 p1 t0 t1 i x0 x1)
 (setvar "cmdecho" 0)
 (command "._undo" "_begin")
 (if (and
  (progn
   (repeat 2
    (setq x0 (polar t0 (ma:qang (angle t0 t1)) (* i 400.0)))
    (setq x1 (polar t1 (ma:qang (angle t0 t1)) (* i 400.0)))
    (command "._line" "_none" (polar x0 (angle x1 x0) 75.0)
	              "_none" (polar x1 (angle x1 x0) (* (distance x0 x1) 0.15))
    (setq i (1+ i) t0 x1 t1 x0)
  ); progn
 ); if
 (command "._undo" "_end")
 (setvar "cmdecho" 1)
 (princ)
(defun c:lisp2 (/ p0 p1 p2 p3 p4 colHead len)
 (if (and
  (progn
   (setq colHead (distance p1 p2))
   (setq i 1)
    (setq p4 (polar p3 (ma:qang (angle p0 p1)) (* i 400.0)))
    (command "._line"
	    (polar p4 (angle p0 p1) (+ (/ colHead 2) (* len edge)))
	    (polar p4 (angle p1 p0) (+ (/ colHead 2) (* len edge)))
    (setq i (1+ i))
   ); foreach
  ); progn
 ); if
 (princ)
Thank you so much. Now it works just perfectly Smiley Happy
