SAVE AS
SAVE AS
W_T_
SAVE AS
W_T_
Is it possible to set it with LISP?
EnM4st3r
vla-put-saveastype
example:
(vla-put-saveastype (vla-get-opensave (vla-get-preferences (vlax-get-acad-object))) ac2018_dwg)
hak_vz
(defun c:savetover2010 nil
	(vl-load-com)
	; 64 - autocad 2018
	; 60 - autocad 2013
	; 48 - autocad 2010
	; 36 - autocad 2007
	; 24 - autocad 2004
	; 12 - autocad 2000
	(vla-put-saveastype
		(vla-get-opensave
				(vla-get-application (vlax-get-acad-object))
		48
	(vla-Save  (vla-get-activedocument (vlax-get-acad-object)))
	(princ)
Miljenko Hatlak
W_T_
どうもありがとうございました。
W_T_
どうもありがとうございました。
勉強になりました。
martti.halminen
Please note that this only affects the SAVEAS -command default format. Regardless of this setting, the SAVE command will still save in the newest format.
- If that can also be changed, I'd be rather interested to know how...
