Program to update Raster Image file path
I've been trying to teach myself AutoLISP solely to fix the pesky issue of my raster images being blown in my projects every time I open them. The only thing I have been able to find was the use of the (-image) command and action recorder. Because you need to know the name or file path already within (-image) instead of just selecting on the wanted image, I have been trying to make a program that stores the image name and current file path from selection and then inputs it into the (-image) command. For example:
After typing -image in command prompt, you are given a list of options. The actrecord will select the Path option. From there when you are prompted to insert a new file path (in this case its the exact same because they're blown images), the program will take the stored file path and input it there.
I know its a lot but searching through as many forums I can get, this might be the best way. If not, I would love to hear your opinions on how best to go about fixing these broken raster images.
Thanks.
