Run list of lisps in folder by another lisp
cool.stuff
cool.stuff
Hi!!!
I have a list of lisp routines that I would like to load from another lisp.
The list is:
flat.lsp
offsetfmp.lsp
clline.lsp
These are a few lisp routines that I have in a folder.
It is possible to create a lisp named "drawLISP.lsp" that would load these at once please?
Many thanks in advance 🙂
Kent1Cooper
Rather than the Startup approach, it sounds like you don't necessarily want them loaded in every drawing.  For a routine to load them on demand, I would make drawLISP.lsp and include in it simply:
(load "flat")
(load "offsetfmp")
(load "clline")
You don't even need to include the .lsp filetype endings.  Then APPLOAD drawLISP.lsp to have it load the others.
If you want them loaded in every drawing whenever you open it, rather than on demand, you can just include those same lines in acaddoc.lsp.
This all assumes that those .lsp files are in a folder where AutoCAD knows to look.  Otherwise, filepaths would need to be added.
Kent Cooper, AIA
