run lisp, script or Macros to select objects without interactiving with AutoCAD
michaelZCXYL
Message 1 of 36
michaelZCXYL
I am wondering if anyone can answer the below question,
How to avoid to interactive with AutoCAD to run lisp, script or Macros to select objects, for example, revision clouds, circle, block, thank you very much in advance.
Replies (35)
Message 21 of 36
michaelZCXYL
see below, thanks, 🙂
Message 22 of 36
michaelZCXYL
Sorry about it, this is my final request list,
1. create new layer "clouds", move clouds to clouds layer, freeze clouds layer.
2. handle multiple drawings at one time
Thank you very much. 🙂
Message 23 of 36
ronjonp
@Sea-Haven wrote:
Yes can be added, but take a step back and think about what you want past this new request, its frustrating just getting please add this multiple times. Ronjonp is helping you I am sure he would prefer the full request list.
@Sea-Haven  Yes, someone that can fully ask a thorough question is always appreciated but there seems to be a language barrier which is not uncommon. Agreed it's frustrating ....
Message 24 of 36
michaelZCXYL
So far is good enough, is it possible to make the following changes?
create a new layer "A", move clouds to A layer, freeze or off A layer.
Sorry about it. next time, I will make sure to present my questions clearly and ask my colleague/friends to check them, thanks. 🙂
Message 25 of 36
ronjonp
Make these changes to the code in the first part of the thread and you'll get your frozen layer 'A'.
Message 26 of 36
michaelZCXYL
It works, great job! Can I use "off" instead of "freeze"? Many thanks.
Message 27 of 36
ronjonp
@michaelZCXYL
Lets see if you can figure it out. HERE is your reference .. drill into the LAYER object, then look at properties. Values to set: 0 = :vlax-false, -1 = :vlax-true.
Let me know how it goes 👍
Message 28 of 36
michaelZCXYL
Hello Ronjonp,
I am very happy to learn new stuff. As I am a little busy right now, I will try to figure it out later. There is one more question in another post, I am wondering if you are interested in it, thank you very much.
Have a good weekend,
Michael 🙂
Message 29 of 36
michaelZCXYL
I have accepted your solution, thanks. 🙂
Message 30 of 36
ronjonp
Actually you've accepted your solution? 🤔
Message 31 of 36
michaelZCXYL
It is a mistake, sorry about it. Could you please advise me how to accept your solution? Also, I am wondering if you can add the following part in the beginning,
set the current layer to 0,
Thank you very much in advance, 🙂
Message 32 of 36
ronjonp
To accept the solution you have to go HERE then accept. As far setting layer 0 current, simply add this to the code at the top: (setvar 'clayer "0")
Be advised his will error if layer 0 is frozen.
Message 33 of 36
michaelZCXYL
Great, it works. I have accepted your solution and hope I did it right this time. I have another question in another post, I am wondering if you are interested in it? Thank you very much in advance. 🙂
Message 34 of 36
Kent1Cooper
@ronjonp wrote:
.... As far setting layer 0 current, simply add this to the code at the top: (setvar 'clayer "0")
It will also have a problem if Layer 0 is turned off -- it will set it current, but it will not turn it on.  So I suggest this:
(command "_.layer" "_thaw" "0" "_set" "0" "")
which will take care of the possibility that it's frozen, and in the process of setting it current by the (command) approach will turn it on if it's off [unlike the (setvar) approach] -- no need for an explicit "_on" option.
Kent Cooper, AIA
Message 35 of 36
michaelZCXYL
I find a another different lisp, it work on multiple drawing at one time. I am wondering if you are interested in combing your FOO lisp with that one. I may create another post for this question, thank you very much in advance.
Message 36 of 36
michaelZCXYL
Hello Kent. I just saw your message. Is Your suggestion script, could you please write in lisp? Thanks
@ronjonp Hello Ronjonp, I have one more question. The lisp work on the clouds which I just created, but it did not work on existing clouds, could you please provide some advice to me, many thanks.
