RRENAME lisp help!
RRENAME lisp help!
lzedCB
Message 1 of 9
RRENAME lisp help!
lzedCB
Hello, I'm trying to replace the all dots (".") by a "_" caractere in all blocks names using a LISP called RRENAME, like the image bellow:
I've tried to find in help file how to get this task done, but I can't find. Anyone can help me with the right expressions?
Replies (8)
Message 2 of 9
Kent1Cooper
Without seeing "a LISP called RRENAME," it's hard to say....
EDIT:  I found >it<.  With limited investigation, it seems a  .  is a wildcard representing any character in patterns, and even looking at the instructions text file's "regular expression" link, I didn't find any reference to an escape character or other means to have that taken literally instead of as a wildcard.  I suspect some way of doing that is going to be necessary, but I'm not versed in such things.
Kent Cooper, AIA
Message 3 of 9
lzedCB
Message 4 of 9
paullimapa
You can try out my free BlockApps that  includes DDBlkRen a block renaming function. You can review how to use with the included video tutorial demo:
https://apps.autodesk.com/ACD/en/Detail/Index?id=3309945226076337959&appLang=en&os=Win64
Paul Li
IT Specialist
@The Office
Message 5 of 9
lzedCB
Seems amazing this your plugin, but I can't test it in C3D. It does not shows up in Addins tab! Thks
Message 6 of 9
paullimapa
In that case I’m not sure it’ll work in C3D
Paul Li
IT Specialist
@The Office
Message 7 of 9
Kent1Cooper
@lzedCB wrote:
.... I'm trying to replace the all dots (".") by a "_" caractere in all blocks names ....
For that particular task, this is enough [limited testing]:
(while
  (setq blk (tblnext "block" (not blk)))
  (setq bname (cdr (assoc 2 blk)))
  (if (and (not (assoc 1 blk)) (wcmatch bname "*`.*"))
    (command "_.rename" "block" bname (vl-string-translate "." "_" bname))
EDIT:  Corrected something, removed an unneeded element, and added prevention of trying to rename an Xref [just in case].
Kent Cooper, AIA
Message 8 of 9
lzedCB
Thanks! That was simple and effective in this task!
Message 9 of 9
Moshe-A
@lzedCB  hi,
check this
enjoy
Moshe
(defun c:rrename (/ _elimPunto tbl bname)
 (setq _elimPunto (lambda (bn) (vl-string-translate "." "_" bn)))
 (while (setq tbl (tblnext "block" (not tbl)))
  (setq bname (cdr (assoc '2 tbl)))
  (if (vl-string-search "." bname)
   (command "._rename" "_block" bname (_elimPunto bname))
 ); while
 (princ)
