Rotated text in scr script
Hi all.
This is my .scr script where the text is rotated:
_.layer n rack_inspector_green c 92 rack_inspector_green r rack_inspector_green
_.circle 1000,1000 350
_.circle 1000,1000 330
; -layer r 0
_.text g c 1000,800 400 0 M
I've just set "keyboad input" in Options/User preference but i can't solve the problem.
Moreover, i've used it without any problems for months.
What could be the problem?
Many thanks.
Gianluca.
ВeekeeCZ
Would you copy/paste here the command-line listing when SCR was run?
dbhunia
I think your *.scr should be like the attached file......(Its tested in AutoCAD 2007 hopefully work in upper version)
The "RED" marked value in the line "_.text j mc 1000,1000 400 90 M" controls the rotation of text ....... change it as your required rotation angle....
I do not know why I was unable to attach "Test.scr" file in "Message-1", so I just renamed it as "Test.scr.txt"  attached it again......
You please Rename it from "Test.scr.txt" to "Test.scr".....
Debashis Bhunia
Co-Founder of Geometrifying Trigonometry(C)
________________________________________________
Walking is the First step of Running, Technique comes Next....
Kent1Cooper
This may not fix it, but....
Your r option in two Layer commands [one commented out] appears to be intended to [reset?] make a given Layer current, but that should be done with the set option.  R is for the rename option, which needs to be given two  text strings, one a current Layer name and a second for what you want to change its name to.  Is it renaming your rack_inspector_green Layer and changing it to _.circle [because that's coming in where it would be asking for the new name]?
It doesn't look like you have a completion  of the Layer command, in a Script typically a blank line, as in the commented-out one.  [EDIT:  @dbhunia put that in their attached file -- I was reacting to its not being in Message 1.]
Kent Cooper, AIA
Hi all.
Thks for reply.
My original script is correct but i must select "STANDARD" as Text style in Annotation.
See attacched screen!
Gianluca.
ВeekeeCZ
Go to the Text Style and check whether is Height set to 0 on some other value.
Then see the command line:
Current text style:  "Standard"  Text height:  2.50  Annotative:  No  Justify:  Left
Specify start point of text or [Justify/Style]:
Specify height <2.50>: 2.5 ; this prompt occurs only when text height is 0.
Specify rotation angle of text <0.000>:
Current text style:  "Standard"  Text height:  1.00  Annotative:  No  Justify:  Left
Specify start point of text or [Justify/Style]: ; <- in this case is the height set to 1, so no prompt here.
Specify rotation angle of text <0.000>: 0
