Rotate the active viewport using a tool palette macr
reuter.philipp
Message 1 of 10
reuter.philipp
I want to create a macro in the tool palette to rotate the active viewport by -90 degrees, but unfortunately it doesn't work like that and I don't get anywhere, where is the error or is there a better way to create the command for English and German as a macro? The main problem is the _R / Rotate subcommand in _MVSETUP;_A;_R:0,0,0;-90, because unfortunately it doesn't exist, as with the other parameters?
(setq v (vl-registry-read (strcat "HKEY_LOCAL_MACHINE"(chr 92)(vlax-product-key)) "Language"))(if (= v "Deutsch")(command "_MVSETUP" "_A" "D" "0,0,0" "-90" "")(command "_MVSETUP" "_A" "R" "0,0,0" "-90" ""))
_MVSETUP;_A;(setq v (vl-registry-read (strcat "HKEY_LOCAL_MACHINE"(chr 92)(vlax-product-key)) "Language"))(if (= v "Deutsch")(command "D")(command "R"));0,0,0;-90;
Greetings,
Philipp
Replies (9)
Message 2 of 10
johnyDFFXO
_MVSETUP;_A;_R:0,0,0;-90;;
... don't you have just a typo in it?
_MVSETUP;_A;_R;0,0,0;-90;;;
Message 3 of 10
reuter.philipp
No, in the German Version i get those result with your sugestions:
Macro: _MVSETUP;_A;_R:0,0,0;-90;;
Befehl: _MVSETUP
Option eingeben [Ausrichten/Erstellen/ansichtsfenster Skalieren/Optionen/schrifTfeld/Zurück]: _A
Option eingeben [Winkel/Horizontal/Vertikal/ansicht Drehen/Zurück]: _R:0,0,0
Ungültiger Optionstitel.
Macro: _MVSETUP;_A;_R;0,0,0;-90;;;
Working German Macro: _MVSETUP;_A;_D;0,0,0;-90;;;
But I just saw that it sets the view to -90 instead of rotating it, what can I do?
Greetings,
Philipp
Message 4 of 10
johnyDFFXO
Try this macro? Does it do what you want?
_MSPACE;_UCS;_W;_DVIEW;;_TW;270;;_UCS;_P;_PSPACE;
Message 5 of 10
pendean
Community Legend
Community Legend
If an abbreviation does not work, why not just use the full command name instead?
Message 6 of 10
reuter.philipp
Yes, _MSPACE;_UCS;_W;_DVIEW;;_TW;270;;_UCS;_P;_PSPACE; produces the same result like _MVSETUP;_A;_R;0,0,0;-90;;; but I should be able to use it for all and I originally wanted it to rotate the view 90 degrees clockwise, currently I need to set up 4 buttons to switch between the 4 views (N: 0, E: 90, S: 180, W: 270).
But thanks for the help!
Philip
Message 7 of 10
johnyDFFXO
Ok then, that's new. How about the old-fashioned approach...
_MSPACE;_UCS;_Z;90;_PLAN;;_PSPACE;
PLAN might not be needed if you use UCSFOLLOW...
Message 8 of 10
Sea-Haven
Maybe look at Angdir variable as default is set to Counter clockwise. 0 or 1.
Message 9 of 10
reuter.philipp
Yes, that was exactly what I was looking for, I removed the _PSPACE; because I want to stay in the current view, so my macros are:
  • _MSPACE;_UCS;_Z;90;_PLAN;; -> Rotates the viewport 90 degrees clockwise
  • _MSPACE;_UCS;_Z;180;_PLAN;; -> Rotates the viewport 180 degrees clockwise
  • _MSPACE;_UCS;_Z;270;_PLAN;; -> Rotates the viewport 270 degrees clockwise
Thanks for the help and also to everyone else for their time!
Best regards,
Philip
Message 10 of 10
Sea-Haven
My $0.05
Save this as a lsp file eg mylisp.lsp
(defun c:AHdoro ( / ans )
(if (not AH:Butts)(load "Multi Radio buttons.lsp"))
(setq ans (atof (ah:butts 2 "V" '("Choose a angle " "45" "90" "135" "180" "225" "270" "315" "other")))) ; ans holds the button picked as an integer value
(command "_MSPACE" "_UCS" "_Z" ans "_PLAN" "")
(princ)
(c:AHdoro)
Your macro is (load "mylisp") ahdoro
