Rotate text according to ucs angle
carlos_m_gil_p
Message 1 of 14
carlos_m_gil_p
Hello, how are you?
I wanted to ask you a favor to improve a Lisp project I'm working on.
I've used the Plant command to rotate the screen according to the UCS.
I need to select some text so it appears horizontal, according to the UCS.
But I don't understand why it works with some text and not with others.
Here's a DWG file where I'm testing and the code I wrote.
(defun c:xxx (/ sel i e ang)
  (setq sel (vl-catch-all-apply 'ssget (list '((0 . "MTEXT,TEXT")))))
  ; (setq ang (angle '(0 0 0) '(1 0 0)))
  (setq ang (angle (trans '(0.0 0.0 0.0) 1 0) (trans '(1.0 0.0 0.0) 1 0)))
  (repeat (setq i (sslength sel))
    (setq e (entget (ssname sel (setq i (1- i)))))
    (entmod (subst (cons 50 ang) (assoc 50 e) e)))
I'd appreciate any help you can give me.
AutoCAD 2026.1.1
Visual Studio Code 1.105.1
AutoCAD AutoLISP Extension 1.6.3
Windows 10 - 22H2 (64 bits)
Replies (13)
Message 2 of 14
Sea-Haven
Have you looked at the 210 dxf code it may do what you want not tested.
(210 0.0 0.0 -1.0) is text at 0.0 angle in world UCS
(210 0.0 -1.0 0.0) is text rotated in 3d 90 about the X axis
Message 3 of 14
carlos_m_gil_p
Hi bro, thanks for responding.
I just checked the 210 code, but all the texts are the same.
(210 0.0 0.0 1.0)
AutoCAD 2026.1.1
Message 4 of 14
paullimapa
post a sample dwg and point out the text that do work vs text that don't
Paul Li
IT Specialist
@The Office
Message 5 of 14
ВeekeeCZ
You can't treat MTEXT and TEXT the same way.
While TEXT behaves as expected, the angle is always stored according to WCS; the MTEXT angle is, for some reason, stored according to UCS.
Message 6 of 14
Sea-Haven
I may be going down the wrong path, Having another look at this for text & mtext.
The BC is in world (210 0.0 0.0 1.0)
The DEF is in a ucs of 90 rotated about X (210 0.0 -1.0 0.0)
Using Mtext
The qwert is world (210 0.0 0.0 1.0)
The ASDF is UCS (210 0.0 -1.0 0.0)
View in 3D
Message 7 of 14
komondormrex
hey you there,
check the following.
(defun c:rot (/ rotation)
	(mapcar '(lambda (m_text) (if (= "AcDbText" (vla-get-objectname m_text))
				    (setq rotation (- (angle '(0 0 0) (getvar 'ucsxdir)) (vla-get-rotation m_text)))
				    (setq rotation (- (angle '(0 0 0) '(1 0 0)) (vla-get-rotation m_text)))
		   		  (vla-rotate m_text (vla-get-insertionpoint m_text) rotation)
  		 (mapcar 'vlax-ename->vla-object (vl-remove-if 'listp (mapcar 'cadr (ssnamex (ssget '((0 . "MTEXT,TEXT")))))))
	(princ)
Message 8 of 14
carlos_m_gil_p
Hello, how are you?
I just want all the text I select to be horizontal and read from left to right.
AutoCAD 2026.1.1
Message 9 of 14
carlos_m_gil_p
Hello, how are you?
I'm just realizing right now that they don't work the same.
AutoCAD 2026.1.1
Message 10 of 14
carlos_m_gil_p
Hello, how are you?
This isn't what I'm looking for right now. As I mentioned above, I just want all text and mtext to be horizontal.
It doesn't matter if I have the screen or the UCs rotated.
AutoCAD 2026.1.1
Message 11 of 14
carlos_m_gil_p
Hi, how are you?
I just ran the tests, and it works great in this dwg file I posted.
But I ran a new test where I set the entire screen to normal and rotated it 90 degrees.
But when I use your function again, the text remains vertical.
Is there a way to improve that?
I turned it from here.
I am attaching a new dwg where I am doing the new tests.
AutoCAD 2026.1.1
Message 12 of 14
carlos_m_gil_p
Hey guys, I just found a routine from Mr. Lee_Mac, and it works fine.
And with lee_mac's permission, I wonder if there's a way to modify the getorient function.
It's possible to make it get the angle itself so it doesn't have to select two points on the screen.
In the tests I've run, getorient determines the direction of the text, so I always select two points horizontally from left to right, and all the text always remains horizontal.
(defun c:xxx (/ ss ang e eLst xAng e)
  ; Lee Mac  ~  16.04.10[/i]
  (if
    (and
      (setq ss (ssget "_:L"
                      '((-4 . "<OR")
                        (0 . "*TEXT,ATTDEF")
                        (-4 . "<AND")
                        (0 . "INSERT")
                        (66 . 1)
                        (-4 . "AND>")
                        (-4 . "OR>"))))
      (setq ang (getorient "\nSpecify Angle: ")))
    ((lambda (i)
       (setq xAng (angle '(0.0 0.0 0.0) (trans (getvar 'UCSXDIR) 0 (trans '(0.0 0.0 1.0) 1 0 t))))
       (while (setq e (ssname ss (setq i (1+ i))))
         (cond
           ((eq "INSERT" (cdr (assoc 0 (setq eLst (entget e)))))
            (while (not (eq "SEQEND" (cdr (assoc 0 (setq eLst (entget (setq e (entnext e))))))))
              (entmod (subst (cons 50 (+ ang xAng)) (assoc 50 eLst) eLst))))
           ((entmod (subst (cons 50 (if (eq "MTEXT" (cdr (assoc 0 eLst))) ang (+ ang xAng))) (assoc 50 eLst) eLst))))))
      -1))
  (princ))
AutoCAD 2026.1.1
Message 13 of 14
carlos_m_gil_p
Hey guys, I just found a routine from @Lee_Mac and it works fine.
And with Lee_Mac's permission, I wonder if there's a way to modify the getorient function.
  (if
    (and
                      '((-4 . "<OR")
                        (-4 . "<AND")
                        (0 . "INSERT")
                        (66 . 1)
                        (-4 . "AND>")
                        (-4 . "OR>"))))
    ((lambda (i)
         (cond
      -1))
  (princ))
AutoCAD 2026.1.1
Message 14 of 14
komondormrex
hey, rot custom command will rotate {m}texts to align with x axle of the current ucs, which in your very case of rtext2 drawing is pretty vertical. so they surely will stay vertical.
