Roof main connection drawing with LiSP
Message 1 of 8
I have a rectangle-square lisp that works with 3 dots. lisp F8 can draw straight or oblique rectangle in open or closed position. available lispe I'm trying for an extra lisp but I'm very inexperienced. I want help for lisp that draws the corners and midpoint of the roof. The sample I put in the appendix I painted red in DWG
I want to have the lines drawn with the help of lisp.
I put the attachment in the current lispi (command R4)
I translated into English with converter. But you can see what I want to say by looking at the drawings.
Replies (7)
Message 2 of 8
hak_vz
In attachment you have modified file with function R5 that create roof. Be careful not to overwrite your old file, save it with new name. I don't have time to test it for all angle combinations, so you will learn sequence to pick 3 points in right order to create good result. If this works for you set this as a SOLUTION.
Miljenko Hatlak
Message 3 of 8
ronjonp
THIS will do what you want as well and on a variety of shapes. 🙂
Message 4 of 8
Hello, the address you forwarded to me was very useful. I'm looking for a very uncomplicated roof because I found a solution to my problem. They are very, very thankful. I am trying to update my letterhead tags and dynamic blocks from excel to ease the business obligation to automate my drawing. I would like to transfer the properties of the blocks in Autocad to excel table and update them via CSV file. Thanks again for the roof LISP.
Message 5 of 8
mirqalib.m
hello. Could you send me the LISP, please?
Message 6 of 8
mirqalib.m
Message 7 of 8
Kent1Cooper
[Have you followed the link in Message 3?]
Kent Cooper, AIA
Message 8 of 8
Sea-Haven
pretty sure there was a 3d version out there as well.
