Create a Dashed line using two endpoints
Message 1 of 11
I am looking for a code that will insert a dashed line that spans the distance between two predetermined endpoints but am unsure what this code would look like, currently I have a small code for insertion of a line: (command "line" "First point" "Second point" "") but I am unsure how to make this code insert a dashed line instead of the solid line it is inserting currently. Any help is appreciated!
Replies (10)
Message 2 of 11
dlanorh
Is "Dashed" Linetype loaded?
I am not one of the robots you're looking for
Message 3 of 11
yes it is
Message 4 of 11
dlanorh
This function will do that
(defun makeline (s_pt e_pt lyr)
  (entmakex (list
              '(000 . "LINE")
              '(100 . "AcDbEntity")
              '(100 . "AcDbLine")
              (cons 10 s_pt)
              (cons 11 e_pt)
              (cons 8 lyr)
              '(6 . "DASHED")
);end_defun
It is called like this (makeline start_point end_point layer). Brackets are not optional, but red layer items are optional (if you just want it on the current layer), if you don't want them remove the red items.
Or did you want to select the points
Message 5 of 11
im unsure if I am placing my point variables in the incorrect spots but when running this lisp it keeps returning an error that is stating I have too few arguments. If the endpoint variables I am using are labelled as "bip" and "ohd" am I placing these in the wrong place within the code?
(defun c:makeline (bip ohd)
(entmakex (list
'(000 . "LINE")
'(100 . "AcDbLine")
(cons 10 bip)
(cons 11 ohd)
'(6 . "DASHED2")
)));end_defun
P.S. I apologize I am relatively new to auto lisp and still learning some of the ropes
Message 6 of 11
dlanorh
(entmakex (list
'(000 . "LINE")
'(100 . "AcDbLine")
(cons 10 bip)
(cons 11 ohd)
'(6 . "DASHED2")
)));end_defun
If you want to run it from the command line then
(defun c:makeline ( / s_pt e_pt ent)
  (setq s_pt (getpoint "\nSelect Line Start Point : ")
        e_pt (getpoint "\nSelect Line End Point : ")
        ent (entmakex (list
                        '(000 . "LINE")
                        '(100 . "AcDbLine")
                        (cons 10 s_pt)
                        (cons 11 e_pt)
                        '(6 . "DASHED")
  );end_setq
);end_defun
Here you will need to select the start and end points on screen
If you already have the start and end points saved in variables, then load the below
(defun makeline (s_pt e_pt)
(entmakex (list
'(000 . "LINE")
'(100 . "AcDbLine")
(cons 10 s_pt)
(cons 11 e_pt)
'(6 . "DASHED2")
)));end_defun
This can be called from the command line like this
(makeline bip ohd)
This is a function and doesn't have a "c:" preceding the command name and so must be included in brackets
bip and ohd must be lists of three elements (list x y z) x coord y coord and z (level) coord.
Message 7 of 11
CodeDing
@dlanorh
Personally, it's the little details that stand out to me 😉
  (initget 1) (setq s_pt (getpoint "\nSelect Line Start Point : "))
  (initget 1) (setq e_pt (getpoint s_pt "\nSelect Line End Point : "))
  (setq ent (entmakex (list '(0 . "LINE") '(100 . "AcDbEntity") '(100 . "AcDbLine")
			    (cons 10 s_pt) (cons 11 e_pt) '(6 . "DASHED")
		      );list
	    );entmakex
  );setq
  (princ)
);defun
Best,
~DD
Message 8 of 11
hak_vz
@dlanorhhas pointed all what is necessary to entmake a line. Good practice would be (at least I see it that way) to have a predefined layer with all attributes already set (linetype, color, lineweigth .....). Newly created object will then inherit all those attributes from layer definition. Then you don't have to think if linetype definition is loaded and so on...
Miljenko Hatlak
Message 9 of 11
I see what you were saying earlier, thank you for the help it is very much appreciated!
Message 10 of 11
ronjonp
Agreed about the little details. FWIW .. I'd use (If (and rather than initget so you don't have to {esc} out of the program.
Maybe also check that dashed is actually loaded since that seems to be a key part of this intricate routine 🙂
(defun c:makeline (/ s_pt e_pt)
  (if (tblobjname "ltype" "DASHED")
    (while (and	(setq s_pt (getpoint "\nSelect Line Start Point : "))
				'(100 . "AcDbLine")
				(cons 10 s_pt)
				(cons 11 e_pt)
				'(6 . "DASHED")
    (alert "Load DASHED linetype please...")
  (princ)
Message 11 of 11
Kent1Cooper
@Anonymous wrote:
... I have a small code for insertion of a line: (command "line" "First point" "Second point" "") but I am unsure how to make this code insert a dashed line ....
I agree that it's a good plan to put it on a Layer with a Dashed linetype.  But it's not necessary to load that linetype ahead of time, nor to check whether it's loaded, if you use the (command) function to make the Layer, rather than (entmake).
(command
  "_.Layer" "_make" "YourLayerName" "_ltype" "DASHED" "" ""
  "_.line" Firstpoint Secondpoint ""
That's one of the advantages of the (command) function [in addition to taking less code] -- it will find  linetypes that are in the ACAD.lin file, in a LAYER or CHPROP [or CHANGE with Properties option] command, even when they do not yet exist in the drawing!
If you have a good reason to want the linetype to be a property override  on the Line, rather than getting that from its Layer:
(command
  "_.chprop" "_last" "" "_ltype" "DASHED" ""
again, whether or not the linetype is already loaded.
Kent Cooper, AIA
