Notice: Upload of PDF documents is currently unavailable across the Community due to an ongoing issue.
REVCLOUD command has different options when invoked from lisp
Blue_Mojito
Blue_Mojito
I have LT 2026. When I type "revcloud" on my command line I get these options:
Specify first corner point or [Arc length/Object/Rectangular/Polygonal/Freehand/Style/Modify/Layer] <Object>:
However, when I add either "revcloud" or "_.revcloud" on the lisp and run it, it resorts to these options:
Command: RC
Command:
Select the block to determine arc size:
Select objects:
_.REVCLOUD
Minimum arc length: 20'-11 1/2" Maximum arc length: 20'-11 1/2" Style: Normal Type: Freehand
Specify start point or [Arc length/Object/Style] <Object>: _Rectangular
Point or option keyword required.
; error: Function cancelled
Does anyone know if there's something wrong with the way the command is invoked through lisp? I've attahced my lisp.
Kent1Cooper
Many commands operate somewhat differently from with an AutoLisp (command) function.  Look into preceding it with (initcommandversion).
Kent Cooper, AIA
Blue_Mojito
Thanks man. I just had to run it a couples time to figure the sequence of inputs, but ended with this:
(initcommandversion "REVCLOUD" 2)
 (command "_.REVCLOUD" "a" arc1)
ronjonp
@Blue_Mojito Here's another that sets the arclen length based on dimscale and puts the cloud on a layer "_Revision_<USER>_<CURRENTDATE>
(defun c:rvc (/ *error* idt_dimscale e n ln vars vals)
  (defun *error* (msg)
    (if	(not (wcmatch msg "Function cancelled,quit / exit abort,console break,end"))
      (princ (strcat "\nError: " msg))
    (mapcar 'setvar vars vals)
    (princ)
  (defun idt_dimscale (n)
    (* n
       (cond ;;in viewport
	     ((and (= 0 (getvar 'tilemode)) (> (getvar 'cvport) 1)) (last (trans '(0 0 1.0) 3 2)))
	     ;;in pspace or dimscale is 0
	     ((or (= (getvar 'cvport) 1) (= 0 (getvar 'dimscale))) 1.)
	     ;;in modelspace
	     ((getvar 'dimscale))
  (setq	ln (strcat "_Revision_"
		   (getenv "username")
		   "_"
		   (menucmd "M=$(edtime, $(getvar,date),YYYY.MO.DD)")
  (setq f (tblobjname "layer" ln))
  (setq n (idt_dimscale 0.3))
  (setq vars '(revcloudarcstyle revcloudarcvariance revcloudapproxarclen revcloudcreatemode))
  (setq vals (mapcar 'getvar vars))
  (mapcar 'setvar vars (list "Calligraphy" 0 n 2))
  ;;  REVCLOUDCREATEMODE (System Variable)
  ;;  Specifies the default input for creation of revision clouds.
  ;;  Type:  Integer
  ;;  Saved in:  Registry
  ;;  Initial value:  1
  ;;  Value  =  Description
  ;;    0    =  Freehand
  ;;    1    =  Rectangular
  ;;    2    =  Polygonal
  (setq e (entlast))
  (command-s "_.revcloud")
  (or (equal e (setq e (entlast))) (entmod (append (entget e) (list (cons 8 ln)))))
  ;; Make layer RGB red if it did not exist already
  (or f (entmod (append (entget (tblobjname "layer" ln)) '((420 . 16711680)))))
  (princ)
Posted a version HERE a while back too.
Blue_Mojito
Thanks. I actually do my annotation (including revs) in model space. I have titleblocks all over with different scales, so I do all my scaling based on these, even my dimscales. But I shall steal this code for my future reference.
