´Resizing all viewports lisp stuck
I am stuck with this. My goal is to resize all viewports with the same center. You set length and width and the work will be automatic...
I do not know how to code the assignment of the length and width to each viewport.
Although, i am thinking if it would be easier to copy the size of the selected viewport to all.
any suggestion?
(Defun c:1 ( / factor1 factor2 vps)
      (initget 1)
      (setq factor1 (getreal "\nEnter length: "))
      (setq factor2 (getreal "\nEnter width: "))
       (setq vps (ssget "_X" '((0 . "Viewport") (-4 . "/=") (69 . 1))))
       (repeat (sslength vps)
                           (setq e (vlax-ename->vla-object (ssname vps 0)))
                           (setq cscale (vla-get-CustomScale e))
      (vlax-invoke e (vlax-get e 'Center) factor1)
      (vlax-invoke e (vlax-get e 'Center) factor2)
      (vla-put-CustomScale e cscale)
                           (ssdel (ssname vps 0) vps)
      (princ)
marko_ribar
Not sure, but this worked for me...
(defun c:1 ( / factor1 factor2 vps i e cscale )
  (vl-load-com)
  (initget 7)
  (setq factor1 (getdist "\nPick or enter height : "))
  (initget 7)
  (setq factor2 (getdist "\nPick or enter width : "))
  (setq vps (ssget "_X" '((0 . "VIEWPORT") (-4 . "/=") (69 . 1))))
  (repeat (setq i (sslength vps))
    (setq e (vlax-ename->vla-object (ssname vps (setq i (1- i)))))
    (setq cscale (vla-get-customscale e))
    (vla-put-height e factor1)
    (vla-put-width e factor2)
    (vla-put-customscale e cscale)
  (princ)
HTH., M.R.
Marko Ribar, d.i.a. (graduated engineer of architecture)
It worked for me too! thanks a lot.
I has a low level at lisp, but i'm trying other code. Now you select one viewport, it gets height, width and center and then, it applies to all viewports. but it doesnt work...
(defun c:1 ( / factor1 factor2 factor3 vps i e cscale )
  (vl-load-com)
	(setq tw(entsel" Select a Viewport:"))
	(setq factor1 (vla-get-height tw))
	(setq factor2 (vla-get-width tw))
	(setq factor3 (vla-get-center tw))
    (vla-put-center e (vlax-3D-point factor3))
  (princ)
marko_ribar
(setq tw (vlax-ename->vla-object (car (entsel "\nSelect a Viewport..."))))
HTH., M.R.
I had to make another change.. and now it works perfectly... thanks!!
(defun c:ret2 ( / factor1 factor2 factor3 vps i e cscale )
  (vl-load-com)
	(setq tw (vlax-ename->vla-object (car (entsel" Select a Viewport:"))))
    (vla-put-center e factor3)
  (princ)
