Help to add converter to attached lisp
arshadmirza786
arshadmirza786
It is a very good lisp by http://esurveying.net/land-survey/free-lisps
I need a modification to add a unit convertor with option Y/N
When select (m) than all so convert to (ft) and when select (ft) than to (m)
"62_Mark_Chain"
marko_ribar
If you haven't noticed that file is *.fas - protected lisp file and can't be modified... You should study what it does and create replication of routine in *.lsp form where you could do your desired intervention with converting (ft) to (m) and opposite (m) to (ft)...
Marko Ribar, d.i.a. (graduated engineer of architecture)
