Request to Modify the lisp (Delete Overwrite Dimension & (X and Y) Dimension Text Are Above
Gaganpatel
Message 1 of 12
Gaganpatel
Dear Sir,
Request to modify the lisp delete overwrite dimension and (X & Y ) dimension text are above.
Please see the Example Drawing & lisp programming.
Replies (11)
Message 2 of 12
Sea-Haven
You can move the dimension text after you make it. A lot of code to wade through as need 4 directions.
(setq obj (vlax-ename->vla-object (entlast)))
(setq tpos (mapcar '+ (vlax-get obj 'TextPosition) (list 125.0 (- 120.0) 0.0)))
(vlax-put obj 'TextPosition tpos)
 Hopefully this example shows how to move the dim text. The (entlast) is your dim.
Message 3 of 12
Gaganpatel
Dear Sir,
 I don't auto lisp programming please help complete the programming.
Message 4 of 12
Kent1Cooper
You can get the text above the lines by simply defining the Dimension Style for that:
And given a Dimension Style defined that way, the QDIM command with the Ordinate option does pretty well at this without a routine, and without duplicating Dimensions [here used twice, once for each direction]:
Kent Cooper, AIA
Message 5 of 12
Gaganpatel
Dear Sir,
Thanks for reply.
Please help complete the programming.
Message 6 of 12
Sea-Haven
Please look at Kent1Cooper solution the best answer.
Message 7 of 12
Gaganpatel
Dear Sir,
Yes this programming is best.
Can you please modify my post programming.
Please help me Sir.
Message 8 of 12
Gaganpatel
Dear Sir,
Please help me any body.
Message 9 of 12
Kent1Cooper
If the suggestion in Message 4 does not do what you want, describe in detail how you want it to be different.
Kent Cooper, AIA
Message 10 of 12
Gaganpatel
Dear Sir,
Thanks for replay .
I want to attached lisp programming modify please.
1) All dimension text are above required.
2) Delete Overwrite dimension .
Please see the attached example file
Message 11 of 12
Kent1Cooper
You haven't really answered my request, but I find it may not matter anyway.  Unfortunately, QDIM doesn't dimension to Block insertion points.  In my earlier image, I had drawn Circles, and it will work with those.  If I Explode your Blocks and use the Circles, and define a Dimension Style appropriately, I get this with no custom routine and just four QDIM commands [including use of the datumPoint and Ordinate options]:
except that the non-right-angle corners were Dimensioned in the results from the opposite sides, so I Erased two of the resulting Dimensions.
But I assume you're not going to want to Explode Blocks to do this....
Kent Cooper, AIA
Message 12 of 12
Gaganpatel
Dear Sir,
QDIM , ordinate dimension is best way.
Can you modify my post lisp programming as per requirement.
