replacing objects (cirlce/recltangle/polygons with geometric center) with a predefined block
hello this is my first time posting on this forum, I hope you could all help me with a lisp.
I have already found a solution for this problem last year, but my office computer encountered "blue screen of death" so goodbye to all my files, including all the lisps I have been using. I tried looking for the same solution but i can no longer find the exact lisp I need.
a lot of layout I receive are not made thru AutoCAD so many objects I need to replace with blocks
an example is this object below, this is made purely of separate lines, not polylines.
what I do is convert these lines to polylines and join them to make a closed octagon.
I need a lisp that can then replace all these octagon (or whatever shape that I make out of) to a specified block.
scaling not needed.
Kent1Cooper
Search for "BLOCKIFY".
Kent Cooper, AIA
blockify made all everythig on my drawing like this.
I need something that would only replace the objects that i selected.
Quickfix found.
a - selected objects to be replaced
b - select block to replace
not the perfection solution, but it will do for now. if you have any other suggestion, would be great
Sea-Haven
