Blockify
Blockify
jtm2020hyo
Message 1 of 11
Blockify
jtm2020hyo
exist any lisp alternative to blockify by bricsys?
https://help.bricsys.com/hc/en-us/articles/360010228153-Blockify
blockify by cadforum actually does not work for me in a 2D drawing:
https://www.cadforum.cz/cadforum_en/sel2blkref-replace-repeating-objects-with-block-references-tip12...
Replies (10)
Message 2 of 11
chau.npt
I have created an application that can work on Autocad exactly similar to BLOCKIFY of BricsCAD. Please see link below for preview:
Gif_Review
Message 3 of 11
jtm2020hyo
awesome.
...can you share us that beautiful routine?
Message 4 of 11
marko_ribar
@chau.npt
I have excersise for you : Can you create few groups with circles randomly positioned and with same radiuses that are scattered in DWG and rotated randomly... Then show us how your blockify routine work with this situation... And in your gif you showed picked selection converted to block... Now show us rotated insertions with groups as blocks I mentioned... I believe you are cheating, and BTW I have LISP that can do correct blockifyications with your situation - this is no big challenge... If I find some time I may show you how my routine works. For now you have to trust me on what I explained...
Marko Ribar, d.i.a. (graduated engineer of architecture)
Message 5 of 11
marko_ribar
You can download my version from here :
http://www.theswamp.org/index.php?topic=55186.0
(You have to be logged in order to access and download)
P.S. There is description in topic, as I didn't have a time to record demonstration...
HTH., M.R.
Message 6 of 11
jtm2020hyo
@marko_ribar wrote:
@chau.npt
please, teach us sensei @marko_ribar  sama
Message 7 of 11
byou19
Can you share the file in .lsp format?
Message 8 of 11
jtm2020hyo
master
I cannot create objects with only one element
Message 9 of 11
there are 2  app which such function
1)https://www.youtube.com/watch?v=ULRYU_REsgw
2)There are russian forum. use APEL.fas with command (apel-com '(apel-draw-find_analog_objects)) https://dwg.ru/dnl/9487 https://forum.dwg.ru/showthread.php?t=156762&page=2
BUT any command don't work when block was ROTATED before explode. Like here https://forum.dwg.ru/showpost.php?p=1862257&postcount=27
Message 10 of 11
3)https://www.cadforum.cz/cadforum_en/sel2blkref-replace-repeating-objects-with-block-references-tip12...
it don`t work at me
"Select also similar objects (=type+layer)? [Yes/No] <No>:
; error: AutoCAD variable setting rejected: "3DOSMODE" 0"
Message 11 of 11
marko_ribar
I've just replied at theswamp... If you need VLX for A2008, try my recompiled version from theswamp...
Regards, M.R.
