replacement for dos_filedate
HE-MJJ
Message 1 of 26
HE-MJJ
I'm trying find a replacement for dos_filedate.
I thought by using vl-file-systime, but vl-file-systime apparently does not return a value of a file that is opened which dos_filedate does. As you can see in results below:
_$ (vl-file-systime "H:\\0000\\0000\\Tekeningen\\BT\\0000_BT-BB-022A.dwg")
nil
_$ (vl-file-systime "H:\\0000\\0000\\Tekeningen\\BT\\0000_BT-BB-022.dwg")
(2024 3 5 15 12 31 56 0)
_$ (dos_filedate "H:\\0000\\0000\\Tekeningen\\BT\\0000_BT-BB-022A.dwg")
(("0000_BT-BB-022A.dwg" . 2.02404e+07))
_$
Does anyone know a working alternative for dos_filedate to obtain the date of an opened drawing?
Replies (25)
Message 21 of 26
HE-MJJ
When I check now, the results for both dos_filedate and dos-filedate are te same:
; form dos_filedate loaded
_$
_1_$
(("0000_BT-BB-022.dwg" . 2.02403e+07))
_1_$
_1_$
_$
; form dos-filedate loaded
_$
_1_$
(("0000_BT-BB-022.DWG" . 2.02403e+07))
_1_$
(("0000_BT-BB-022A.DWG" . 2.02404e+07))
_1_$
_$
Then why isn't the date and time displayed the same?
Message 22 of 26
EnM4st3r
@HE-MJJ wrote:
I seem to be almost there...
This is my replacement for dos_filedate so far:
for the first part of your if you could just go like this
  (if (setq fnm-d (vl-file-systime fnm))
    (setq fnm-d-j (apply 'ctoj (reverse (cddr (reverse fnm-d)))))
and put together you could go like this, but dont know what dos-splitpath does:
(defun dos-filedate (fnm / fnm-d fnm-d-j)
  (cond
    (fnm-d (setq fnm-d-j (apply 'ctoj (reverse (cddr (reverse fnm-d))))))
    ((= (strcase (strcat (getvar "dwgprefix") (getvar "dwgname"))) (strcase fnm))
     (setq fnm-d-j (getvar "tdupdate"))
  (if fnm-d-j
    (list
      (cons (strcat (nth 2 (dos-splitpath fnm)) (nth 3 (dos-splitpath fnm)))
            fnm-d-j
    fnm
Message 23 of 26
HE-MJJ
This is my code so far: It replaces the Doslib function.
(defun dos-filedate (fnm / fnm-d fnm-d-j )
(progn
(setq fnm-d-j (jtod (dtoj (atoi (strcat (rtos (nth 0 fnm-d) 2 0) (strnr (rtos (nth 1 fnm-d) 2 0) 2) (strnr (rtos (nth 3 fnm-d) 2 0) 2) "." (strnr (rtos (nth 4 fnm-d) 2 0) 2) (strnr (rtos (nth 5 fnm-d) 2 0) 2)(strnr (rtos (nth 6 fnm-d) 2 0) 2)))))) ; Check: (rtos (jtod fnm-d-j) 2 6)
(setq fnm (list (cons (strcat (nth 2 (dos-splitpath fnm)) (nth 3 (dos-splitpath fnm))) fnm-d-j)))
(if (= (strcase (strcat (getvar "dwgprefix") (getvar "dwgname"))) (strcase fnm)) ; Bij dit geopende bestand
(progn
(setq fnm-d-j (jtod (getvar "tdupdate"))) ; Check: (rtos (jtod fnm-d-j) 2 6)
fnm
What I don't get is why the time isn't displayed for one of the drawings that use the same dos-filedate function.
Message 24 of 26
HE-MJJ
I ran into another issue:
(dos_filedate "H:\\0000\\0000\\Tekeningen\\BT") results in (("BT" . 2.02406e+07))
But
(vl-file-systime "H:\\0000\\0000\\Tekeningen\\BT") results in nil
How (under AutoCAD LT) can I obtain the date of a folder?
Message 25 of 26
HE-MJJ
I don't get it why (with my latest code) the date is obtained but hours and minutes do not seem to be obtained from the file.
Message 26 of 26
EnM4st3r
have you tried my code from message 22?
