Replace Text Is it Possible
jaimuthu
Message 1 of 9
jaimuthu
I have more than 5000 hatch object with leader and text the text is show area of the hatch its area wrong, i want select all hatch exisitng leader text value is replace to correct  area of text here i attach file what i want
Replies (8)
Message 2 of 9
vladimir_michl
It will be quite complicated to "follow the line" from the Text to the proper Object (hatch). It might be easier to use fields (maybe fields inside MLeader) to re-create the labels.
Vladimir Michl, www.arkance.world  -  www.cadforum.cz
Message 3 of 9
-didier-
Bonjour @jaimuthu (depuis la France).
Here is the program I propose.
I tested it, and it works in your example environment.
I have redefined the alignment of the text to the right point and the width of the text so that it is only on one line
If you have any problems, I thank you for letting me know and we will discuss.
Here is the video of my screen :
(view in My Videos)
Amicalement
Éternel débutant.. my site for learning : Programmer dans AutoCAD
DA
Message 4 of 9
jaimuthu
great job
Message 5 of 9
jaimuthu
great job thanks for 1000000 times
Message 6 of 9
-didier-
Bonjour @jaimuthu
I’m happy if it’s useful.
Beware of units they can prohibit the selection that I imagined.
If you see any errors, please let me know and I will make adjustments.
Amicalement, from France.
DA
Message 7 of 9
paullimapa
excellent coding...I also added the following for @jaimuthu
1. Place Text on specified Layer "TEXT" and Color "2" Yellow:
    (setq txtlyr "TEXT" ; layer for text
          txtcol "2"    ; color for text
2. Created Field value for Hatches Layer & Area values so that the next time these change they're updated automatically:
;                (setq la (vlax-get-property h 'layer))
 (setq la(strcat "%<\\AcObjProp Object(%<\\_ObjId " (itoa(vla-get-ObjectID h)) ">%).Layer>%")) ; create layer as field
;                (setq ha (/ (vlax-get-property h 'area) 1000000.0))
 (setq ha(strcat "%<\\AcObjProp Object(%<\\_ObjId " (itoa(vla-get-ObjectID h)) ">%).Area \\f \"%lu2%pr2%ct8[1.000000000000000E-006]\">%")) ; create area as field
;                        (setq val (strcat "Layer: " la ", Area: " (rtos ha 2 2) " sq.m"))
                        (setq val (strcat "\\C" txtcol ";Layer: " la ", Area: " ha " sq.m")) ; layer & area as field in color
                        (vlax-put-property tex  'Layer txtlyr)
Paul Li
IT Specialist
@The Office
Message 8 of 9
-didier-
Bonjour @paullimapa
Thank you.
Your improvement is a perfect idea.
Amicalement
DA
Message 9 of 9
paullimapa
You are welcome…cheers!!!
Paul Li
IT Specialist
@The Office
