Replace only selected blocks with a different one LISP
Message 1 of 22
Hello world,
I found this nice LISP on a CADTutor forum (kudos to Smirnoff) for replacing block and transferring attributes and some properties (layer, rotation, scale). I was wondering if someone was able to upgrade the code to also take note of the dynamic block action parameters like flip state, rotation, scale etc. and transfer it to the new dynamic block that had the same parameters?
Br,
Robert
(defun c:xch(/ iCnt bSet cFlg nBlc cVal pLst
	         bNam aLst aDoc nBlc aSp cAt rLst)
  (vl-load-com)
  (defun Set_Initial_Setenv(varLst)
    (mapcar
      '(lambda(v)(if(not(getenv(car v)))(setenv(car v)(cadr v))))
      varLst)
    ); end of Set_Initial_Setenv
  (defun Unblock_All_Layers(/ aDoc layCol actLay outLst)
     (setq aDoc(vla-get-ActiveDocument
		 (vlax-get-acad-object))
	   layCol(vla-get-Layers aDoc)
	   actLay(vla-get-ActiveLayer aDoc)
	   ); end setq
      (vlax-map-collection layCol
        (function
	  (lambda(x)
	    (setq outLst
	      (cons
		(list x
	       	      (vla-get-Lock x)
	              (vla-get-Freeze x)
	             )outLst)
		  ); end setq
	    (vla-put-Lock x :vlax-false)
	     (if(not(equal x actLay))
              (vla-put-Freeze x :vlax-false)
	    ); end if
	   ); end lambda
	  ); end function
	); end vlax-map-collection
  outLst
  ); end of Unblock_All_Layers
  (defun Restore_All_Layer_States(Lst / actLay)
     (setq actLay(vla-get-ActiveLayer
		     (vlax-get-acad-object))))
      (mapcar
       (function
	 (lambda(x)
	   (vla-put-Lock(car x)(cadr x))
	    (if(not(equal actLay(car x)))
              (vla-put-Freeze(car x)(last x))
	    ); end if
        Lst
  (princ)
  ); end of Restore_All_Layer_States
(Set_Initial_Setenv '(("xchange:layer" "Yes")("xchange:scale" "Yes")
		      ("xchange:rotation" "Yes")("xchange:attributes" "Yes")))
  (princ "\n<<< Select blocks to replace >>> ")
  (if(setq bSet(ssget '((0 . "INSERT"))))
    (progn
      (while(not cFlg)
	(princ
	  (strcat "\nOptions: Layer = "(getenv "xchange:layer")
	          ", Scale = " (getenv "xchange:scale")
	          ", Rotation = " (getenv "xchange:rotation")
	          ", Attributes = " (getenv "xchange:attributes")))
         (initget "Options")
         (setq nBlc(entsel "\nSelect new block or [Options] > "))
	(cond
	  ((and
	     (= 'LIST(type nBlc))
	     (equal '(0 . "INSERT")(assoc 0(entget(car nBlc))))
	     ); end and
	   (setq nBlc(vlax-ename->vla-object(car nBlc))
		 cFlg T); end setq
	   ); end condition #1
	  ((= 'LIST(type nBlc))
	   (princ "\n<!> This isn't block <!> ")
	   ); end condition #2
	  ((= "Options" nBlc)
	    (initget "Yes No")
	    (setq cVal(getkword(strcat "\nInherit old block layer [Yes/No] <"
				       (getenv "xchange:layer")">: ")))
	    (if(member cVal '("Yes" "No"))(setenv "xchange:layer" cVal))
	    (initget "Yes No")
	    (setq cVal(getkword(strcat "\nInherit old block scale [Yes/No] <"
				       (getenv "xchange:scale")">: ")))
	    (if(member cVal '("Yes" "No"))(setenv "xchange:scale" cVal))
	    (initget "Yes No")
	    (setq cVal(getkword(strcat "\nInherit old block rotation [Yes/No] <"
				       (getenv "xchange:rotation")">: ")))
	    (if(member cVal '("Yes" "No"))(setenv "xchange:rotation" cVal))
	    (initget "Yes No")
	    (setq cVal(getkword(strcat "\nInherit attributes with similar tags [Yes/No] <"
				       (getenv "xchange:attributes")">: ")))
	    (if(member cVal '("Yes" "No"))(setenv "xchange:attributes" cVal))
	   ); end condition #3
	  ); end cond
	); end while
      (setq aDoc(vla-get-ActiveDocument(vlax-get-acad-object))
	    bNam(vla-get-Name nBlc)
	    aSp(vla-ObjectIdToObject aDoc(vla-get-OwnerId nBlc))
	    iCnt 0
	    ); end setq
      (vla-StartUndoMark aDoc)
      (setq rLst(Unblock_All_Layers))
      (foreach b(mapcar 'vlax-ename->vla-object
			 (vl-remove-if 'listp
			   (mapcar 'cadr(ssnamex bSet))))
	(if(= :vlax-true(vla-get-HasAttributes b))
	    (setq aLst
		   (mapcar '(lambda (a)
			      (list (vla-get-TagString a)
				    (vla-get-TextString a)))
			   (vlax-safearray->list
			     (vlax-variant-value (vla-GetAttributes b)))))
	  ); end if
	(setq nBlc(vla-InsertBlock aSp (vla-get-InsertionPoint b)bNam 1.0 1.0 1.0 0.0))
	  (if(= "Yes"(getenv "xchange:layer"))
	   (vla-put-Layer nBlc(vla-get-Layer b))
	  ); end if
         (if(= "Yes"(getenv "xchange:scale"))
	   (progn
	     (vla-put-XScaleFactor nBlc(vla-get-XScaleFactor b))
	     (vla-put-YScaleFactor nBlc(vla-get-YScaleFactor b))
	     (vla-put-ZScaleFactor nBlc(vla-get-ZScaleFactor b))
	    ); end progn
	  ); end if
	(if(= "Yes"(getenv "xchange:rotation"))
	   (vla-put-Rotation nBlc(vla-get-Rotation b))
	  ); end if
	(if
	  (and
	     (= "Yes"(getenv "xchange:attributes"))
	     (= :vlax-true(vla-get-HasAttributes nBlc))
	    ); end and
	  (foreach i(mapcar '(lambda (a)(list(vla-get-TagString a)a))
			          (vlax-variant-value(vla-GetAttributes nBlc))))
	    (if(setq cAt(assoc(car i)aLst))
	      (vla-put-TextString(last i)(last cAt))
	      ); end if
	    ); end foreach
	  ); end if
	(vla-Delete b)
	(setq iCnt(1+ iCnt))
	); end foreach
      (Restore_All_Layer_States rLst)
      (vla-EndUndoMark aDoc)
      (princ(strcat "\n" (itoa iCnt) " block(s) was replaced. "))
      ); end progn
    (princ "\n<!> Nothing selected <!>" )
    ); end if
  (princ)
 ); end of c:xch
Replies (21)
Message 2 of 22
john.uhden
See if this simplistic version works for you...
;;; BlockSwap replaces selected blocks.
;;; by John Uhden (updated 03-09-17)
(defun c:BlockSwap ( / *error* vars ok name1 obj1 name2 obj2 opt ss)
  (vl-load-com)
  (defun *error* (err)
    (mapcar '(lambda (x)(setvar (car x)(cdr x))) vars)
    (vla-endundomark *doc*)
    (cond
      ((not err))
      ((wcmatch (strcase err) "*CANCEL*,*QUIT*"))
      (1  (princ (strcat "\nERROR: " err)))
    (princ)
  (or *acad* (setq *acad* (vlax-get-acad-object)))
  (or *doc* (setq *doc* (vla-get-ActiveDocument *acad*)))
  (vla-startundomark *doc*)
  (setq vars (mapcar '(lambda (x)(cons x (getvar x))) '("cmdecho")))
  (mapcar '(lambda (x)(setvar (car x) 0))  vars)
  (command "_.expert" (getvar "expert")) ;; dummy command
  (while (not ok)
    (setq obj1 (vlax-ename->vla-object (car (entsel "\nPick old block: "))))
    (princ (strcat "  Old block name = \"" (setq name1 (vla-get-name obj1)) "\""))
    (setq  obj2 (vlax-ename->vla-object (car (entsel "\nPick new block: "))))
    (princ (strcat "  New block name = \"" (setq name2 (vla-get-name obj2)) "\""))
    (if (= name1 name2)
      (prompt "\nSame old and new blocks selected.")
      (setq ok 1)
  (initget "Replaceall Select")
  (setq opt (getkword
        "\nEnter an option [Select/Replaceall] <Replaceall> ... "
      opt (if opt opt "Replaceall")
  (cond
    ((= opt "Select")
      (prompt "\nSelect blocks to be replaced...  ")
      (setq ss (ssget (list (cons 0 "INSERT") (cons 2 name1))))
    ((= opt "Replaceall")
      (setq ss (ssget "X" (list (cons 0 "INSERT") (cons 2 name1))))
  (repeat (setq i (sslength ss))
    (vla-put-name (vlax-ename->vla-object (ssname ss (setq i (1- i)))) name2)
  (vla-regen (vla-get-activedocument (vlax-get-acad-object))
       acActiveViewport
  (*error* nil)
(defun c:BS ()(c:BlockSwap))
John F. Uhden
Message 3 of 22
lleeLFG9Q
Community Visitor
Community Visitor
Was looking for this command and found your LISP.
Looked online for information to load a LISP into cad.  Only thing I would add for those that may need this information is that I copied the LISP code and pasted it into notepad on my windows, then saved it and renamed the file with a .lsp extension at the end.  Then I loaded it into cad following the online instructions I found.
Message 4 of 22
john.uhden
@lleeLFG9Q ,
I am thrilled that you found it.
I don't remember writing or posting it or even where I was at the time.  I must have been unemployed because I am not independently wealthy, and am thankful to be working now because I can't afford to retire.  My wife refuses to understand that this is my hobby, which takes precedence over most of my domestic duties, except doing the garbage and recycling and paying the bills, which score no points at all.
If it works for you, please accept my solution.  A little gratitude is a welcome thing.
John F. Uhden
Message 5 of 22
Sea-Haven
Re the dynamic block use existing values, if you get a copy of Lee-Mac's dynamic block lisp it has all the necessary code to get the values out then put them into the new block.
Message 6 of 22
Tom2023
Hi John,
Amazing coding. Now, how do we not copy the scale? So the Destination Block will retain its original Scale?
Thank you
Message 7 of 22
john.uhden
@Tom2023
Never thought about that.
Maybe I'll have time to look into that this weekend.
John F. Uhden
Message 8 of 22
Tom2023
Thank you John. You're the greatest 😊
Message 9 of 22
Tom2023
Hi John, your (updated 03-09-17) block swap lisp is amazing! I use this several times a day!
Is it possible to add an error catch when picking? If I accidentally click on empty space, the program stops and I have to run it again.
Something like
 Please Pick again?
Thank you John. Your lisp is amazing!
Message 10 of 22
john.uhden
@Tom2023 ,
Luckily I was just holding up dinner when I found your response.
I hope this update improves your usage.
;;; Updated (04-15-23) per request of @Tom2023 to warn but coninue
;;; with erroneous picks.
(defun c:BlockSwap ( / *error* vars vals ok name1 obj1 name2 obj2 opt ss)
  (vl-load-com)
    (mapcar 'setvar vars vals)
    (cond
      ((not err))
    (princ)
  (setq vars '("cmdecho"))
  (setq vals (mapcar 'getvar vars))
  (while (not ok)
    (and
      (if
        (and
          (= (vlax-get obj1 'ObjectName) "AcDbBlockReference")
        (prompt "\nObject not selected or is not a block reference.")
      (if
        (and
          (= (vlax-get obj2 'ObjectName) "AcDbBlockReference")
      (if (= name1 name2)
        (setq ok 1)
  (setq opt (getkword
  (cond
    ((= opt "Select")
       acActiveViewport
  (*error* nil)
John F. Uhden
Message 11 of 22
Tom2023
Hi John, I hope your dinner was delicious and memorable. I don't know what I did wrong but the program still stop and exit if I accidentally click on empty space.
It's no big deal. There's no rush. Please enjoy your dinner, John. I'm still using your lisp everyday regardless. Thank you John.
Message 12 of 22
john.uhden
@Tom2023
I think my hunger and the aroma made me hasty.  I will fix.
John F. Uhden
Message 13 of 22
pdecanio1
@john.uhden
I came across this and is similar to something I was working on. Are you able to modifiy this to allow for "effective names"?
        (princ (strcat "  Old block name = \"" (setq name1 (vla-get-effectivename obj1)) "\""))
      (if
        (and
        (princ (strcat "  New block name = \"" (setq name2 (vla-get-effectivename obj2)) "\""))
I modified this part and it seemed to work and put the effective names in instead of the *U name autocad gives dynamic blocks...
This is what i get when testing it
Would be very useful.
Thanks in advance
Message 14 of 22
Kent1Cooper
Unfortunately, that's because the <Replaceall> option tries (ssget)-ing with filtering for the Block name.  It's one thing to get the effective name from a dynamic Block insertion, but sadly, (ssget) cannot filter for that, because it doesn't show up anywhere in the insertion's entity data, which is what the filter is looking at.  I suspect it will be necessary, in the case of a source Block being dynamic, to have it select all Blocks, and step through getting the effective name of each to compare to that of the source.
Kent Cooper, AIA
Message 15 of 22
pdecanio1
@Kent1Cooper
Thanks for the response.
I am no code guru, I can look and somewhat modify and write some easy stuff.
I am not sure how to do what you just mentioned.
Can the name be saved to a variable and just us that variable to be the block names?
I am fine with all blocks in the whole drawing with the saved name to changed.
Message 16 of 22
Kent1Cooper
Maybe we should let @john.uhden do the modification, but questions arise:
What if the source and the target Blocks are not of the same variety [i.e. either not both "plain" or not both dynamic]?  Would you ever want to replace one of one variety with one of the other variety?  Should it check that they're both the same kind?
And if a dynamic Block can be replaced just by changing its effective Block name, as a plain one can, what happens to whatever dynamic property settings or values it had?  Do the old and new Block definitions need to have the same dynamic ingredients?
Kent Cooper, AIA
Message 17 of 22
pdecanio1
@Kent1Cooper
We have alot of old drawings that have old blocks we have to go back to sometimes and we would like to update the drawings to our newer blocks. Yes the old attributes may not come over if they dont have the same attribute tags as the new blocks. Which will be the case on some. We are unworried about that we will just make them right.
Alot of our old blocks are not dynamic which we want them to be now, a complete replacement of these is probably what will happen and again if they have or dont have the tag names is something that will have to be dealt with.
Message 18 of 22
pendean
Community Legend
Community Legend
How 'unusable' is the simpler method of INSERTing an old file into a Master template file with your new block definitions already in place for an auto-replacement: old attributes should tag along, same-named blocks and layers get replaced then SAVEAS and tidy-up a smaller list of tasks instead?
Message 19 of 22
Kent1Cooper
@pendean wrote:
.... the simpler method of INSERTing an old file into a Master template file with your new block definitions already in place ....
.... depends on the new Blocks all having the same names as the old ones.  @pdecanio1, is that always the case for you?
Kent Cooper, AIA
Message 20 of 22
pendean
Community Legend
Community Legend
Indeed
