Replace Dynamic Block with Normal Block
MikeKovacik4928
Advisor Advisor
MikeKovacik4928
Hi all you lispers/customisers out there
Hi posted this to the AutoCAD Forum but got no replies,
so I am trying here. See my posts below
*******************************************************8
Hi all you Autocadders and Autodesk Staff world wide
I would like to use a function like blockreplace to replace a  dynamic block with a normal block
I have tried the "blockreplace command". It works beautifully with normal blocks, but doesn't appear to work with
a dynamic block.
Anybody got a method of doing it.
Mike Kovacik
AutoCAD 2d & 3d/Inventor Draughtsman
Joburg South Africa
Okay
Obviously there is no out of the box solution.
I will post this to the customisation forum to see if there an existing lisp solution.
Mike Kovacik
Is there an existing lisp solution for this, that anybody has used
Mike Kovacik
ВeekeeCZ
Original thread HERE
