Replace characters in Mtext's Field Expression
Hi All,
I would like to ask some Autocad filed expression questions, and here is what i need:
In Mtext, it will automatically change a symbol(_) to another symbol(/) after get part of the filename string
For example, i have a file under the path like this: //a/a/b/c/d/A23456789_B23456789_C2_D.dwg
The Mtext will show like this B23456789/C2/D
So I divide the customized field expression(according to my understanding, it means it shows automatically when i placed in the M-Text) into 2 part:
(1)(done already) the first part is to get the filename start from the 11th character and count for 14 value with following code:
%<$(substr,$(getvar,dwgname),11,14)>%
(2)After that, I would like to replace those underline symbol "_" to slash symbol "/" with following code, (which cannot work well and is my question)
%<$(vl-string-translate "_" "//" $(substr,$(getvar,dwgname),11,14))>%  (<--- Can anyone help me for this)
Reference Related:
I have read several posts related to the string replacement and field expression
https://www.augi.com/articles/detail/autocad-fields-forever
https://knowledge.autodesk.com/search-result/caas/CloudHelp/cloudhelp/2016/ENU/AutoCAD-AutoLISP/file...
https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/replacing-substr-s-in-a-string-varia...
Will
ActivistInvestor
You're confusing DIESEL and LISP.
While they are similar, DIESEL functions are a limited subset of LISP functions, and there is no $(vl-string-translate) DIESEL function, so that isn't going to work.
@Anonymous wrote:
Hi All,
Reference Related:
https://knowledge.autodesk.com/search-result/caas/CloudHelp/cloudhelp/2016/ENU/AutoCAD-AutoLISP/files/GUID-57060085-C79D-4613-B438-506AC443BCE7-htm.html
https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/replacing-substr-s-in-a-string-variable/td-p/3783451
Will
Thanks for your answer, so what should i do to make it work?
Satish_Rajdev
Something like this :
(defun replace (s)
  (if (vl-string-search "_" s)
    (vl-list->string
      (subst (ascii "/") (ascii "_") (vl-string->list s))
    s
Examples :-
_$ (replace "B23456789_C2_D")
"B23456789/C2/D"
_$ (replace "//a/a/b/c/d/A23456789_B23456789_C2_D.dwg")
"//a/a/b/c/d/A23456789/B23456789/C2/D.dwg"
Best Regards,
Satish Rajdev
REY Technologies | Linked IN | YouTube Channel
Hi Sir, Thanks for your answers, but is it possible to run in the DIESEL expression ?
If so , can you teach me how to work on it?
ActivistInvestor
I don't believe there's any solution for this with DIESEL.  It just doesn't have the functions required to do it.
jtm2020hyo
I have same issue, Did you found some alternative?
