Centermarks variable "CENTEREXE" problem
zaky73
zaky73
Can't set centermarks variable "CENTEREXE" via lisp...any help.. Thanks
Kent1Cooper
What have you tried?  Does (setvar 'centerexe YourDesiredValue) not work?
Kent Cooper, AIA
zaky73
The value doesn't change if I change it using lisp.
zaky73
(setvar "centerexe" 250) doesn't work
trevor.bird.au
Hi zaky73,
Try (setvar "CENTEREXE" 250.0)
It seems that it has to be a real number when setting the variable from LISP.
Trevor
zaky73
That's help....thank you.
