Replace characters in a text block
I have a text block, block name is "TITLEBLOCKTEXT"
The attribute tag is "PNUM"
I want to replace all instances of the character "A" with "J"
Example = A001 changed to J001.
I found how to change text strings, but nothing related to text in a block.  Any help is much appreciated!!
Kent1Cooper
Will FIND do what you want?  It can change text content within Attributes.
Kent Cooper, AIA
Moshe-A
@Anonymous ,
check this one.
Moshe
(defun c:A2J (/ ss old new)
 (if (setq ss (ssget '((0 . "insert") (2 . "titleblocktext") (66 . 1))))
  (foreach ename (vl-remove-if 'listp (mapcar 'cadr (ssnamex ss)))
   (if (not
          (vl-catch-all-error-p
            (setq old (vl-catch-all-apply
                               'getpropertyvalue (list ename "pnum")))
    (if (or
          (setq new (vl-string-subst "J" "A" old))
          (setq new (vl-string-subst "j" "a" old))
     (vl-catch-all-apply 'setpropertyvalue (list ename "pnum" new))
    ); if
   ); if
  ); foreach
 (princ)
That is going to find all letter A and I only want to replace the character in one attribute (PNUM).  The block contains 20+ attributes, so selecting it returns all character A's.
It works great except it is asking for me to select objects.  Can it select the block text automatically rather than having to select it manually?
I have 200 drawings I need to change
Changing the top line to..
(setq ss (ssget "x" '((0 . "insert") (66 . 1) (2 . "TITLEBLOCKTEXT"))))
Makes it work perfectly.
