Replace block with hatch
Bart_Dheere
Bart_Dheere
After a measurement, I receive a plan with lines and blocks from our surveyor. These 2dpolylines form the line-shaped elements of a road structure. The blocks are the point-shaped elements or an indication of the paving. converting the lines and point elements is semi-automatic. Where there are blocks with the paving, a hatch must be made. A hatch within the lines where the block is. Would there be a possibility to change these blocks to a hatch with a lisp?2019-04-12_13h04_09.jpg
marko_ribar
Not that I know how...
Probably you have to collect blocks... Iterate through collection, explode, recreate boundary from previous exploded selection set (if there is boundary!!!) and then hatch that boundary... Process all collection till finished... In short terms that would be the task, but boundary thingy is little unpredictable IMHO...
Marko Ribar, d.i.a. (graduated engineer of architecture)
