Replace block lisp
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
hello
i have lisp to replace selected blocks with new block ... when i replace blocks ... the new blocks don't inserted into the same place of old blocks ... i want the new blocks location at the same location of old blocks ... can anyone help me ..
(defun c:BLREP (/ ACTDOC COPOBJ ERRCOUNT EXTLST EXTSET FROMCEN LAYCOL MAXPT CURLAY MINPT OBJLAY OKCOUNT OLAYST SCLAY TOCEN TOOBJ VLAOBJ *ERROR* )
(vl-load-com)
(defun *ERROR* (msg)
(if olaySt
(vla-put-Lock objLay olaySt)
); end if
(vla-EndUndoMark actDoc)
(princ)
); end of *ERROR*
(defun GetBoundingCenter (vlaObj / blPt trPt cnPt)
(vla-GetBoundingBox vlaObj 'minPt 'maxPt)
(setq blPt (vlax-safearray->list minPt)
trPt (vlax-safearray->list maxPt)
cnPt (vlax-3D-point (list (+ (car blPt) (/ (- (car trPt) (car blPt)) 2)) (+ (cadr blPt) (/ (- (cadr trPt) (cadr blPt)) 2)) 0.0
); end list
); end vlax-3D-point
); end setq
); end of GetBoundingCenter
(if (not (setq extSet (ssget "_I")))
(progn
(princ "\n<<< Select objects to replace >>> ")
(setq extSet (ssget))
); end progn
); end if
(if (not extSet)
(princ "\n Replace objects isn't selected ")
); end if
(if (and extSet (setq toObj (entsel "\nSelect new object -> ")) ); and and
(progn
(setq actDoc (vla-get-ActiveDocument (vlax-get-Acad-object) )
layCol (vla-get-Layers actDoc)
extLst (mapcar 'vlax-ename->vla-object (vl-remove-if 'listp (mapcar 'cadr (ssnamex extSet)) ) )
vlaObj (vlax-ename->vla-object (car toObj))
objLay (vla-Item layCol (vla-get-Layer vlaObj) )
olaySt (vla-get-Lock objLay)
fromCen (GetBoundingCenter vlaObj)
errCount 0
okCount 0
); end setq
(vla-StartUndoMark actDoc)
(foreach obj extLst
(setq toCen (GetBoundingCenter obj)
scLay (vla-Item layCol (vla-get-Layer obj) )
);end setq
(if (/= :vlax-true (vla-get-Lock scLay))
(progn
(setq curLay (vla-get-Layer obj))
(vla-put-Lock objLay :vlax-false)
(setq copObj (vla-copy vlaObj))
(vlax-put-property copObj "Rotation" (vlax-get Obj "Rotation" ))
(vla-Move copObj fromCen toCen)
(vla-put-Layer copObj curLay)
(vla-Delete obj)
(setq okCount (1+ okCount))
); end progn
(setq errCount (1+ errCount))
); end if
); end foreach
(princ (strcat "\n" (itoa okCount) " were changed. "
(if (/= 0 errCount) (strcat (itoa errCount) " were on locked layer! ") "" ); end if
); end strcat
); end princ
); end progn
(princ "\n New object isn't selected ")
