Renumber the first letter of mtexts in sequence
symoin
symoin
Hi All,
I am looking for a lisp to renumber the first letter of mtexts in sequence.
I need to select the Mtexts and it should change the sl. Number or the first letter of the Mtexts in order or i will select each mtext individually and it should renumber in sequence.
Drawing atttached
Sea-Haven
It should be fairly straight forward look for the "-" then look at what is in front of it and replace with a number, ask before selecting what is start number.
(setq pos (vl-string-position  45 str))
(setq strend (substr str (+ pos 1)))
(setq newstr (strcat (atoi num) strend))
Your home work is select text, strcat, then update text 2 methods entmod or Vla-put-textstring.
symoin
; I TRIED TO CODE BUT THIS IS NOT WORKING.
(defun c:ren ( / ss)
(vl-load-com)
(if (and (setq ss (ssget (list (cons 0 "*text"))))
(princ)
komondormrex
hey there,
check the following
(defun c:re_index_mtext (/ index mtext_sset )
	(if (setq index 0 mtext_sset (ssget '((0 . "mtext"))))
				(foreach mtext (vl-sort (vl-remove-if 'listp (mapcar 'cadr (ssnamex mtext_sset)))
									   '(lambda (mtext_1 mtext_2) (> (caddr (assoc 10 (entget mtext_1))) (caddr (assoc 10 (entget mtext_2)))))
						 (vla-put-textstring (vlax-ename->vla-object mtext)
						 					 (strcat (itoa (setq index (1+ index))) "-"
											 		 (vl-string-left-trim " " (substr (vla-get-textstring (vlax-ename->vla-object mtext))
													 	     						  (+ 2 (vl-string-position (ascii "-") (vla-get-textstring (vlax-ename->vla-object mtext))))
symoin
Thanks komondor mrex
Its working good, can we have an option to ask for the first number? Please
komondormrex
sure
(defun c:re_index_mtext (/ start_index mtext_sset )
	(if (setq mtext_sset (ssget '((0 . "mtext"))))
		(progn
			(initget 6)
			(setq start_index (1- (getint "\nEnter starting index: ")))
						 				 (strcat (itoa (setq start_index (1+ start_index))) "-"
	(princ)
