Renaming Layer lisp , just like the original in autocad but with modification
razkaman
razkaman
Hi
i prepared a script for change layer in multiple drawing, but the problem is , if the layer is been rename, and there is no layer name , they will continue to ask the old layer , and since in script we can't make esc /cancel command, can you tell me how to modified layername change or maybe a lisp for renlayer?
so when the old layer isnt there they will cancel and turn back to "command" or turn to "enter an option(...."
example:
-LAYER
Current layer:  "0"
Enter an option [?/Make/Set/New/Rename/ON/OFF/Color/Ltype/LWeight/TRansparency/MATerial/Plot/Freeze/Thaw/LOck/Unlock/stAte/Description/rEconcile]: r
Enter old layer name: bearing
Enter new layer name: bearing01
Enter old layer name: dim
Cannot find layer "dim".
Cannot find layer "dim". (they always repeating, what i want is they just cancel and back to "command" or to "enter an option (..." again)
ВeekeeCZ
Kent1Cooper
Here's a question:  Do you want to have all the Layers with the new names in all the drawings, whether or not all the Layers with the old names are there already?  That is [using your first example], if a drawing does not already contain a Layer "bearing," do you still want it to have a Layer "bearing01" in it after you run the routine?
If so, you could just force all the old Layer names to exist before renaming things, with a New option in the Layer command and a comma-delimited string of Layer names.  Add something like this before it gets into the Rename options:
-LAYER
N
bearing,dim,this,that,other,whatever,Bob,Carol,Ted,Alice
r
bearing
bearing01
r
dim
.... etc ....
Any of those Layer names that already exist in the drawing will be unaffected by the above [a message will go by that they already exist, but it will continue without error].
Kent Cooper, AIA
razkaman
thank you for the link, it really helpful. so maybe better i insert the lisp first and change layer first with script , and then change the other like color,linetype,lw etc...
razkaman
thank you for your reply.
but it still if i need  rename the layer with script, if the old layer if not exist, the script will be stop
i attached txt and also scr that i made. first i made the txt and then run it in perl and make scr from it.
i using perl because i'm just learn VBA. also don't know how to make lsp, i only make lsp to make command alias, which i don't use it anymore cause we can make command alias since autocad 2010
change layer in scr file.( can't upload the scr file so i write in here)
ltscale 1
-layer R "tse attrib" "D_EX_TSE_ATT" C 7 "D_EX_TSE_ATT" L "Continuous" "D_EX_TSE_ATT" LW 0.25 "D_EX_TSE_ATT" D "EXISTING TSE ATTRIBUTES (ID, DIAMETER, LENGTH, MATERIAL ETC)"
"D_EX_TSE_ATT"  -layer R "air valve" "D_EX_TSE_AVCH" C 240 "D_EX_TSE_AVCH" L "Continuous" "D_EX_TSE_AVCH" LW 0.25 "D_EX_TSE_AVCH" D "EXISTING TSE AIR VALVE CHAMBER"
"D_EX_TSE_AVCH"  -layer R "chamber 59+000" "D_EX_TSE_DCH" C 240 "D_EX_TSE_DCH" L "Continuous" "D_EX_TSE_DCH" LW 0.25 "D_EX_TSE_DCH" D "EXISTING TSE DISCHARGE CHAMBER"
"D_EX_TSE_DCH"  -layer R "C_50OUT" "D_EX_TSE_DICH" C 240 "D_EX_TSE_DICH" L "Continuous" "D_EX_TSE_DICH" LW 0.25 "D_EX_TSE_DICH" D "EXISTING TSE DISTRIBUTION CHAMBER"
"D_EX_TSE_DICH"  -layer R "cancelled_Waterline" "D_EX_TSE_DUCT" C 30 "D_EX_TSE_DUCT" L "Continuous" "D_EX_TSE_DUCT" LW 0.25 "D_EX_TSE_DUCT" D "EXISTING TSE DUCT"
"D_EX_TSE_DUCT"  -layer R "concrete encasement" "D_EX_TSE_FCH" C 240 "D_EX_TSE_FCH" L "Continuous" "D_EX_TSE_FCH" LW 0.25 "D_EX_TSE_FCH" D "EXISTING TSE FLUSHING CHAMBER"
"D_EX_TSE_FCH"
Kent1Cooper
If that's happening even if you make all the old Layer names exist in the drawing, maybe [I'm guessing] those names don't "register" until the Layer command ends, so they're not really there yet for the renaming, as I laid it out before.
If that's the issue, I expect it would work to have a separate Layer command to make the old Layer names exist, complete that, and then start a new one to rename them:
-LAYER
N
bearing,dim,this,that,other,whatever,Bob,Carol,Ted​,Alice
-LAYER
r
bearing
bearing01
r
dim
.... etc ....
Kent Cooper, AIA
