Get ent with max value using APPLY and MAPCAR
ВeekeeCZ
Consultant Consultant
ВeekeeCZ
Hello, I was trying figure out how to get entity name with max number using apply and mapcar.
Example
(setq lst '(("<Entname1>" . 1) ("<Entname2>" . 3) ("<Entname3>" . 2)))
;Goal: Get Entname with max number:
;Result: "<Entname2>"
;PS. String syntax is just for test purpose.
I came up with:  (but for opposite order in pairs...)
Spoiler
(setq emax (cdr (assoc (apply 'max (mapcar 'car lst)) lst)))
Maybe using vl-sort.... but I'am pretty sure there must be better way than using assoc or vl-sort... I have have too little experience with this... Thx.
marko_ribar
This looks robust, but works...
(setq emax (cadr (assoc (apply 'max (mapcar 'car (mapcar 'reverse (mapcar '(lambda ( x ) (list (car x) (cdr x))) lst)))) (mapcar 'reverse (mapcar '(lambda ( x ) (list (car x) (cdr x))) lst)))))
Still (max) or (min) functions are limited to some number of items to process, so I strongly suggest that you construct (maxn) function...
(defun emax ( lst / maxn emax )
  (defun maxn ( l / x r )
    (if (cadr l)
      (progn
        (while (cadr l)
          (if (null r)
            (setq x (car l))
            (setq x r)
          (if (> x (cadr l))
            (setq r x)
            (setq r (cadr l))
          (setq l (cdr l))
        r
      (car l)
  (setq emax (cadr (assoc (maxn (mapcar 'car (mapcar 'reverse (mapcar '(lambda ( x ) (list (car x) (cdr x))) lst)))) (mapcar 'reverse (mapcar '(lambda ( x ) (list (car x) (cdr x))) lst)))))
  emax
Marko Ribar, d.i.a. (graduated engineer of architecture)
(caar (vl-sort lst '(lambda (x y)(> (cdr x )(cdr y)))))
(car (nth (vl-position (apply 'max (setq qlst (mapcar 'cdr lst))) qlst) lst))
In case more than one entity contains the max number:
(mapcar 'car
  (vl-remove-if
    '(lambda (x)
        (cdar
        (cdr x)
  lst
ВeekeeCZ
Thank you guys, I like to see there are various possibilities.
But one thing caught my attention. As I can see, Marco converts dotted list into the regular because reverse function doesn't work with that. I noticed myself before, that (last '(0 . 0)) doesn't work either. So my question is what other limitations has dotted list? Why even use it? I know, it's an essential element definitions for all entities, but...
