Renaming Blocks
Renaming Blocks
JMARTINEZP5F4F
Message 1 of 10
Renaming Blocks
JMARTINEZP5F4F
looking for lsp that'll make renaming blocks faster and easier
Replies (9)
Message 2 of 10
CodeDing
@JMARTINEZP5F4F ,
Can you define what 'Faster' and 'Easier' looks like for you?
Please explain to us what your PERFECT version of renaming blocks looks like.
That should help this thread a bunch
Best,
~DD
Message 3 of 10
Kent1Cooper
My routine for that is the RB command defined in RenameBlock.lsp, attached.  [There are links in the Forum to a site where downloading it is not currently working, and with slightly older versions.]
Just pick a Block insertion, and it asks for a new name in a text-editing box, with the current one filled so you can change just limited parts if you want, or add a suffix or something, but you can edit it to be anything you want.  You do not need to know the current Block name as you would in a RENAME command.
If you want to do this with the wacky Block names created by the PASTEBLOCK command, like "A$Cf53a89dd", you can prevent those completely with an undefinition and redefinition of the command, forcing you to give the resulting Block a meaningful name.  Try PasteBlockWithName.lsp, >here<.  Have that loaded by acaddoc.lsp, and it will operate in all drawings, and you will never get a wacky name again.
Kent Cooper, AIA
Message 4 of 10
pendean
Community Legend
Community Legend
What did you find with a search so far? And why did they not work for you? there are a handful of solutions in this one older post for example
https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/block-rename-lsp/td-p/8432296
Message 5 of 10
JMARTINEZP5F4F
Essentially being able to just highlight the block and run a command to open a dialogue box to edit the name
Message 6 of 10
JMARTINEZP5F4F
not sure if it's because they were for older versions of autocad or maybe i'm just running them incorrectly
Message 7 of 10
Kent1Cooper
That's exactly how RB [Message 3] works, in either noun-verb or verb-noun order.
Kent Cooper, AIA
Message 8 of 10
JMARTINEZP5F4F
Thank you!
Message 9 of 10
pendean
Community Legend
Community Legend
The ones I tested in the link I shared all work just fine. Give them a try.
Message 10 of 10
Kent1Cooper
[But I believe only Message 10 there is about doing what is wanted here.  Other offerings are not about simply changing a Block name in RENAME fashion, but about changing a Block insertion to be an insertion of a different Block name, or creating a duplicate Block with a different name, or such things.]
Kent Cooper, AIA
