Challenge: Encoded Polyline Algorithm
CodeDing
Mentor Mentor
CodeDing
Looking for a challenge?
Try to create this Encoded Polyline Algorithm in AutoLISP:
https://developers.google.com/maps/documentation/utilities/polylinealgorithm
Example:
(setq ptList '((38.5 -120.2) (40.7 -120.95) (43.252 -126.453)))
(EncodePolyline ptList)
_p~iF~ps|U_ulLnnqC_mqNvxq`@   <<--- The correct output string
Why is this relevant?
Many mapping APIs can't afford the extreme overhead of very lengthy polyline coordinate arrays that get provided as parameters; and they don't always need to keep the full precision of a polyline when they're merely overlaying a vector line on a map image. So there needed to be a way to effectively reduce the amount of input data while still outputting the desired product (even if a little precision was lost in the process, it shouldn't be noticeable in the end result).
Attached is my go at it
Happy Coding!
~DD
daniel_cadext
That’s pretty cool, the compression is really good!
could be really handy as a cad utility
Python for AutoCAD, Python wrappers for ARX https://github.com/CEXT-Dan/PyRx
CodeDing
@daniel_cadext ,
Well, it's a Lossy Compression, so idk if that's ideal for CAD software 🤔
can't think of where to apply it
daniel_cadext
lossy because its rounding to single precision
I think if you can encode/decode XYZ coordinates, that could be useful.
Probably the same encoding, if you think of it as an array of floats
Could be used to store points in database blobs or maybe a spreadsheet
