rename only selected blocks
adaptacad
Message 1 of 8
adaptacad
Hello, does anyone have an easy way to rename ONLY the selected blocks. I select and rename only my selection set.
Thank you in advance .
Replies (7)
Message 2 of 8
Shneuph
Are you asking for a way to do this, period?  Or do you specifically need it to be done through LISP?
---sig---------------------------------------
'(83 104 110 101 117 112 104 64 71 109 97 105 108 46 99 111 109)
Message 3 of 8
devitg
@adaptacad  ,
selected by a wildcard name ?
rename by a : newname  list ?
Maybe if you upload a sample.dwg and more data it will be easy to help you
Message 4 of 8
adaptacad
Not necessarily by LISP, I need to rename some selected blocks.
NOTE: Note the RENAME command does not work because I need to select the blocks, ONLY THE SELECTED ones.
Message 5 of 8
Shneuph
This is how I always do it if I have a block in a dwg and I need some of them to be a new block.
I hope it's clear.
f83161bb-86f8-4447-b496-af857c16de0a,640,710
Message 6 of 8
Kent1Cooper
That means you're going to need to have another Block definition with the different name [even if its contents are identical], and replace  those selected Blocks with it.  Once you have that other Block definition established, you can use BlockReplace.lsp with its BRS command, available >here<, to replace selected Blocks with that.
Kent Cooper, AIA
Message 7 of 8
Shneuph
...well... there was supposed to be a screencast but I don't see it in that last post now..
https://knowledge.autodesk.com/community/screencast/f83161bb-86f8-4447-b496-af857c16de0a
Maybe that works?
Message 8 of 8
adaptacad
@Shneuph  @Kent1Cooper Both solutions work, thank you very much!
