Dialog box - Toggle
Dialog box - Toggle
Henrik_Lo
Dialog box - Toggle
Henrik_Lo
Hi
I need some help to get an toggle to work, I newer used this action before, and cannot get it to work.
I can read that I need to keep track on my input, but is not working for me.
Fx. The DCL toggle
   : toggle {
   key = "tg1"; value = 1;
   label = "PDF creator ";
How dos the lisp expression look like do following.
A default value need to do an action, and if I check it out, the action need to be stopped.
could be something like this, just for an example.
   (if (= tg1 “1”)
      (Setq aa “Yes”)
      (Setq aa “No”)
Regards
Henrik
hak_vz
For a start look here at Afralisp.
Miljenko Hatlak
dlanorh
Get the value of the tile before testing using an action_tile in the lisp. action_tile
(action_tile "tg1" "(setq tg1 $value)")
(if (= tg1 "1")
  (setq aa “Yes”)
  (Setq aa “No”)
I am not one of the robots you're looking for
Henrik_Lo
Hi
I know this normal action_tile, I did tray this way, but I couldn’t get is to work, only the first statement is working, I don’t think there will be another value when check it out , only 1 is exciting. I think there need more.
Regards
Henrik
Henrik_Lo
Hi
If found out that I added a value in the DLC file, and it is important not to do that, then i followed AfraLISP regarding toggle dialog, and then It worked.
Thangs for helping out.
Regards
Henrik
Sea-Haven
This may come in handy go to Cadtutor, Downloads and look at "Multi toggles.lsp" it is a library routine can have as many toggles as you need from 1 to screen size limit.
Henrik_Lo
Hi
Thangs for advice
Regards
Henrik
