rename blocks
rename blocks
nychoe1
rename blocks
nychoe1
Hello expert guys.
There is a function to add text in front of the block name in blocks and in blocks
I want to make it possible to add characters after block names
for example,  input text "-a"
< block name >   <suffix>
aaa                  ->    aaa-a
bbb                 ->   bbb-a
ccc                  ->   ccc-a
thanks for reading. some help... expert guys
(defun c:brenpre (/ Blocks *error* cm r ss int sn sfx kw bks nam)
(vl-load-com)
;;; Tharwat 31. Oct. 2012 ;;;
;;; Rename selected or All Blocks as User's inputs ;;;
(or acdoc (setq acdoc (vla-get-activedocument (vlax-get-acad-object))))
(setq Blocks (vla-get-blocks acdoc))
(setq cm (getvar 'cmdecho))
(defun *error* (x)
(if cm
(setvar 'cmdecho cm)
(vla-EndUndoMark acdoc)
(princ "\n")
(princ "\n *Cancel*:")
(if (and (not (eq (setq sfx (getstring t "\pretext")) ""))
(setq r (snvalid sfx))
(progn (initget "Selected All")
(setq kw (cond ((getkword "\nselect <s> or all blocks <all>"))
("Selected")
(if (eq kw "All")
(progn (vla-StartUndoMark acdoc)
(vlax-for x Blocks (vl-catch-all-apply 'vla-put-name (list x (strcat sfx (vla-get-name x)))))
(if (setq ss (ssget "_:L" '((0 . "INSERT"))))
(setvar 'cmdecho 0)
(repeat (setq int (sslength ss))
(setq sn (ssname ss (setq int (1- int))))
(setq nam (cdr (assoc 2 (entget sn))))
(if (not (member nam bks))
(progn (vl-cmdf "_.-rename" "B" nam (setq nam (strcat sfx nam))) (setq bks (cons nam bks)))
(cond ((not sfx) (princ "\n Cancelled by user "))
((not r) (princ "\n Not Valid Block name "))
(t (princ "\n Cancelled by user "))
(princ "\n Written by Tharwat Al Shoufi")
(princ)
paullimapa
try my free app:
BlockApps | AutoCAD | Autodesk App Store
Paul Li
IT Specialist
@The Office
Kent1Cooper
It is a little confusing that the code adds a prefix to Block names but calls the variable name 'sfx.'  But in any case, you should be able to change those three quoted lines to:
(if (and (not (eq (setq sfx (getstring t "\nSuffix: ")) ""))
(vlax-for x Blocks (vl-catch-all-apply 'vla-put-name (list x (strcat (vla-get-name x) sfx))))
(progn (vl-cmdf "_.-rename" "B" nam (setq nam (strcat nam sfx))) (setq bks (cons nam bks)))
Kent Cooper, AIA
nychoe1
thank you. good working
