Edit lisp to draw perpendicular polylines instead of aligned lines
mahmoud.taha.abdalaziz
Hello;
I have a  lisp that gives me the shortest path between blocks and draw  polyline between them, I want to edit the lisp to draw the polyline orthogonally as illustrated in the screenshot,
The lisp in the attached file
Thanks in advance
ВeekeeCZ
(defun c:CONNECTBLKS ( / *error* dynp dynm opt ans osm blk s_pt ss cnt pt_lst e_lst ent p_ent s_param e_param)
  (defun *error* ( msg )
    (if dynp (setvar 'dynprompt dynp))
    (if dynm (setvar 'dynmode dynm))
    (if osm (setvar 'osmode osm))
    (if (and c_doc (= 8 (logand 8 (getvar 'UNDOCTL)))) (vla-endundomark c_doc))
    (if (not (wcmatch (strcase msg) "*BREAK*,*CANCEL*,*EXIT*")) (princ (strcat "\nAn Error : " msg " occured.")))
    (princ)
    );_end_*error*_defun
  (cond ( (/= (getvar 'dynprompt) 1) (setq dynp (getvar 'dynprompt)) (setvar 'dynprompt 1)))
  (cond ( (/= (getvar 'dynmode) 3) (setq dynm (getvar 'dynmode)) (setvar 'dynmode 3)))
  (initget "Closed Open")
  (setq opt "Closed"
	ans (getkword (strcat "\nProduce a [Closed/Open] Polyline < " opt " > : "))
	);end_setq
  (if ans (setq opt ans))
  (cond ( (eq opt "Open")
	 (if (/= (getvar 'osmode) 0) (setq osm (getvar 'osmode)))
	 (setvar 'osmode 0)
	 (setq blk "")
	 (while (/= blk "INSERT")
	   (setq s_pt (cdr (assoc 10 (entget (setq ent (car (entsel "\nSelect Start Block : "))))))
		 blk (cdr (assoc 0 (entget ent)))
		 );end_setq
	   );end_while
	);end_cond
  (setq ans 0)
  (while (< ans 2)
    (if (= opt "Open") (prompt "\nSelect Additional Blocks to Connect : ") (prompt "\nSelect All Blocks to Connect : "))
    (setq ss (ssget '((0 . "INSERT"))))
    (if (and (= opt "Open") (not (ssmemb ent ss))) (setq ss (ssadd ent ss)))
    (setq ans (sslength ss))
    (cond ( (< ans 2) (alert (strcat "Selection Set must contain\n2 DIFFERENT BLOCKS to Connect.\nCurrent Size : " (itoa ans))) (setq ss nil)))
    );end While
  (cond ( (>= (sslength ss) 2)
	 (setq cnt (1- (sslength ss)))
	 (repeat (sslength ss)
	   (setq pt_lst (cons (cdr (assoc 10 (entget (ssname ss cnt)))) pt_lst)
		 cnt (1- cnt)
		 );end_setq
	   );end_repeat
	 (if (= (sslength ss) 2) (setq cpl 0) (setq cpl 1))
	 (setq e_lst (LM:ConvexHull pt_lst)
	       ent (entmakex
		     (append
		       (list
			 '(0 . "LWPOLYLINE")
			 '(100 . "AcDbEntity")
			 '(100 . "AcDbPolyline")
			 (cons 90 (length e_lst))
			 '(62 . 1)
			 (cons 70  cpl)
			 );end_list
		       (mapcar '(lambda ( x ) (cons 10 x)) e_lst)
		       );end_append
		     );end_entmakex
	       );end_setq
	 (if (> (length pt_lst) (length e_lst)) (setq p_ent (ee:spl pt_lst e_lst ent)) (setq p_ent ent))
	 (cond ( (= opt "Open")
		(setq s_param (vlax-curve-getparamatpoint p_ent s_pt))
		(cond ( (= s_param 0.0)
		       (vlax-put-property (vlax-ename->vla-object p_ent) 'closed :vlax-false)
		       );end_sub_cond_start point is start of polyline
		       (setq e_param (1- s_param))
		       (vl-cmdf "_break" p_ent "_F" s_pt (vlax-curve-getpointatparam p_ent e_param))
		       );end_cond_otherwise
		      );end_cond
		);end_sub_cond_open polyline required
	       );end_cond
	 (bk:rightagleing p_ent)  ;; added by BeekeeCZ 22-12-12
	 );end_selection_set
	);end_cond
  (princ)
  );end_defun
;; Convex Hull  -  Lee Mac
;; Implements the Graham Scan Algorithm to return the Convex Hull of a list of points.
(defun LM:ConvexHull ( lst / ch p0 )
  (cond ( (< (length lst) 4) lst)
	( (setq p0 (car lst))
	 (foreach p1 (cdr lst)
	   (if (or (< (cadr p1) (cadr p0))
		   (and (equal (cadr p1) (cadr p0) 1e-8) (< (car p1) (car p0)))
	     (setq p0 p1)
	 (setq lst
		(vl-sort lst
			 (function
			   (lambda ( a b / c d )
			     (if (equal (setq c (angle p0 a)) (setq d (angle p0 b)) 1e-8)
			       (< (distance p0 a) (distance p0 b))
			       (< c d)
	 (setq ch (list (caddr lst) (cadr lst) (car lst)))
	 (foreach pt (cdddr lst)
	   (setq ch (cons pt ch))
	   (while (and (caddr ch) (LM:Clockwise-p (caddr ch) (cadr ch) pt))
	     (setq ch (cons pt (cddr ch)))
	 ch
;; Clockwise-p  -  Lee Mac
;; Returns T if p1,p2,p3 are clockwise oriented or collinear
(defun LM:Clockwise-p ( p1 p2 p3 )
  (<  (-  (* (- (car  p2) (car  p1)) (- (cadr p3) (cadr p1)))
	  (* (- (cadr p2) (cadr p1)) (- (car  p3) (car  p1)))
      1e-8
;; Evgeniy Elpanov's code for shortest polyline
;; adapted for use with Lee Mac's Convex Hull
;; by Ron Harman (dlanorh)
(defun ee:spl (p_lst ll ent / D D0 D1 E EP LS P)
  (defun f1 (a ent / p)
    (setq p (vlax-curve-getpointatparam ent (fix (vlax-curve-getparamatpoint ent (vlax-curve-getclosestpointto ent a))))
	  p (list 10 (car p) (cadr p))
	  );end_setq
    (entmod (append (reverse (member p (reverse (entget ent)))) (list (cons 10 a)) (cdr (member p (entget ent)))))
    );end_defun
  (setq p_lst (mapcar (function cddr)
		      (vl-sort
			(mapcar (function (lambda (a / b) (cons (distance a (setq b (vlax-curve-getclosestpointto ent a))) (cons (vlax-curve-getparamatpoint ent b) a)))) p_lst)
			(function (lambda (a b) (if (equal (car a) (car b) 1) (<= (cadr a) (cadr b)) (< (car a) (car b)))))
			);end_vl-sort
		      );end_mapcar
	ls  p_lst
	);end_setq
  (foreach a ll (setq ls (vl-remove a ls)))
  (foreach a ls
    (setq p (vlax-curve-getparamatpoint ent (vlax-curve-getclosestpointto ent a))
	  p (if (zerop (rem p 1.))
	      (if (zerop p)
		(vlax-curve-getendparam ent)
		(1- p)
		);end_if
	      (fix p)
	      );end_if
	  p (vlax-curve-getpointatparam ent p)
	  );end_setq
    );end_foreach
  (foreach a p_lst (setq ll (vl-remove a ll)))
  (entmod (vl-remove-if (function (lambda (a) (member (cdr a) ll))) (entget ent)))
  (setq p_lst (mapcar (function cdr) (vl-remove-if-not (function (lambda (a) (= (car a) 10))) (entget ent)))
	p_lst (mapcar (function list) (cons (last p_lst) p_lst) p_lst)
	ep (length p_lst)
	d0 (vlax-curve-getdistatparam ent ep)
	);end_setq
  (while  (> d0 (progn
		  (foreach a p_lst
		    (setq e (entget ent)
			  d (vlax-curve-getdistatparam ent ep)
			  );end_setq
		    (entmod (vl-remove (cons 10 (car a)) (vl-remove (cons 10 (cadr a)) e)))
		    (f1 (car a) ent)
		    (f1 (cadr a) ent)
		    (if (<= d (setq d1 (vlax-curve-getdistatparam ent (vlax-curve-getendparam ent))))
		      (entmod e)
		      (setq d d1
			    e (entget ent)
			    );end_setq
		      );end_if
		    (f1 (cadr a) ent)
		    (f1 (car a) ent)
		      (entmod e)
		      (setq d d1
			    e (entget ent)
			    );end_setq
		      );end_if
		    );end_foreach
		  d
		  );end_progn
	     );end_"<"
    (setq d0 d)
    );end_while
  (setq rtn (cdr (assoc -1 e)))
  );end_defun
(defun bk:rightagleing (e / d db dv dv+)
  (setq d (entget e)
	c (= 1 (logand (cdr (assoc 70 d)) 1))
	db (vl-remove-if '(lambda (x) (vl-position (car x) '(10 40 41 42 91 90))) d)
	dv (vl-remove-if '(lambda (x) (/= (car x) 10)) d)
	dv+ (mapcar '(lambda (v1 v2) (if (and (not (equal (cadr v1) (cadr v2) 1e-9))
					      (not (equal (caddr v1) (caddr v2) 1e-9)))
				       (list v1 (list 10 (cadr v1) (caddr v2)))
				       (list v1)))
		    dv (if c (append (cdr dv) (list (car dv))) (cdr dv)))
	dv+ (apply 'append dv+))
  (if (not c) (setq dv+ (append dv+ (list (last dv)))))
  (entmod (append db
		  (list (cons 90 (length dv+)))
		  dv+))
  (if c (setpropertyvalue e "Closed" 1)))
thanks, that's what I need, Thank you BeekeeCZ for your effort.
