Message 1 of 18
I have a csv that I extract data from and update block attributes and properties, then summarized the updated information in an mtext. All of this is working fine, except that some of the csv fields have a tab character at the start of the text, which shows up in the final mtext. The field extracts as a text, as a variable ADDRESSv. My question is would I remove the tab using its ASCII code, or is there some other identifier I should use?
Gorra
