remove tab character from csv data or from mtext
Gorra
Message 1 of 18
Gorra
I have a csv that I extract data from and update block attributes and properties, then summarized the updated information in an mtext. All of this is working fine, except that some of the csv fields have a tab character at the start of the text, which shows up in the final mtext. The field extracts as a text, as a variable ADDRESSv. My question is would I  remove the tab using its ASCII code, or is there some other identifier I should use?
Gorra
Replies (17)
Message 2 of 18
komondormrex
hi,
tab in a string may be  as the "\t" substring.
see there prin1.
Message 3 of 18
paullimapa
best if you upload a sample csv file with at least one row that has that tab character in front of the text that you want to remove so community then can run tests
Paul Li
IT Specialist
@The Office
Message 4 of 18
ec-cad
Could you upload a .csv with the 'tabs' in there, so we can check what to strip ?
ECCAD
Message 5 of 18
ec-cad
You can 'foreach text csvfile, call this routine to strip those tabs.
ECCAD
;; Strip Tab Characters
 (defun strip_tabs ( str )
  (setq L (strlen str)); length of the input string
  (setq ret "" N 1)
  (repeat L
   (setq ch1 (substr str N 1)); single character
   (if (/= ch1 "\t")
    (setq ret (strcat ret ch1))
   ); if
   (if (= ch1 "\t")
    (setq ret (strcat ret " ")); replace with a 'Space
   ); if
   (setq N (+ N 1))
  ); repeat
   ret
); defun
;; Testing
(setq S "TEST\tWITH\tTABS\tIN THE STRING.")
(setq TXT (strip_tabs S))
(princ TXT)
Message 6 of 18
Gorra
Thanks @komondormrex, that's part of what I'm looking for
Message 7 of 18
Gorra
@ec-cad @paullimapa @komondormrex
One of the offending lines is attached.
I tried this function:
(defun RemoveTab (Ln / Chrs)
  (setq Chrs (ascii Ln))
  (if (eq Chrs 9)
    (vl-string-left-trim "\t" Ln)
    (princ)
It ran without errors, but didn't take the tabs out. I'll be trying ec-cad's method this afternoon, unless there's something simple stopping the above from working.
The target data is column N, so position 13 on the list for the row.
Gorra
Message 8 of 18
komondormrex
and the other part(s)?
Message 9 of 18
Gorra
Sorry, now edited to include more
Message 10 of 18
komondormrex
the function will remove all tabs from a string and return tat string.
(defun RemoveTab (line)
     (vl-list->string (vl-remove 9 (vl-string->list line)))
but if you want to rewrite your csv you need firstly to open your csv, read all lines from it into a list, close it, process lines read to the list, open again your csv for writing and write to it all lines processed with the function removetab from the list.
Message 11 of 18
Kent1Cooper
Can you do this with the line read from the .csv file, here put into a variable called 'txt', before splitting it up around the commas?  The (while) part is because the string substitution does only one at a time, in case some line(s) may have more than one.
(while (wcmatch txt "*\t*")
  (setq txt (vl-string-subst "" "\t" txt))
Kent Cooper, AIA
Message 12 of 18
Gorra
@komondormrex
Does the code automatically take the 9 as an ascii character? It runs without error, but the tab is still showing up. I tried replacing the 9 with \t, "\t", and 't but no change
Gorra
Message 13 of 18
Gorra
@Kent1Cooper
Do you mean in the LM:csv->lst function?
Gorra
Message 14 of 18
Kent1Cooper
@Gorra wrote:
.... Do you mean in the LM:csv->lst function? ....
If that's what you use to split the line from the .csv file into separate text strings around the commas.  You could also split it up first, and then do the substitution of an empty string for the tab on each part.  But if you do it to the whole string first, you don't need to do anything about that with the individual strings.
Kent Cooper, AIA
Message 15 of 18
komondormrex
can't be.
see (RemoveTab "\t\t\twqwqqw,\"\tdsdssds\",\t212121,\t21121")-> "wqwqqw,\"dsdssds\",212121,21121".
all tabs are gone.
and yes the code takes all tabs (ascii code 9) from the string, converted to list of ascii codes and returns that string.
and the whole thing may be done as follows
(defun c:de_tab_csv (/ csv_list csv_file csv_file_id line)
	(setq csv_file "your_drive:\\your_path\\your_file.csv"
		  csv_file_id (open csv_file "r")
	(while (setq line (read-line csv_file_id))
		(setq csv_list (append csv_list (list line)))
	(close csv_file_id)
	(setq csv_file_id (open csv_file "w"))
	(foreach line csv_list
		(write-line (RemoveTab line) csv_file_id)
	(close csv_file_id)
updated
Message 16 of 18
Gorra
@komondormrex
It shouldn't be, but it is (attached). Could it be something other than a tab? I've been assuming it is because when I click on the cell, the gap in the formula bar is all one character.
Gorra
Message 17 of 18
Gorra
Ah, I just tested it by princ-ing the variable, and it is coming out as 9 for all the lines affected.
Message 18 of 18
Gorra
Ugh, I wasn't redefining the main variable with the updated string.
Thanks everyone, I'll now hide my head somewhere.
Gorra
