remove layer name
remove layer name
nychoe1
remove layer name
nychoe1
hello guys.
I want to delete all the special characters in the layer name.
if are there special characters like these   --->     @ $, [, ~, {, ],  etc...
I want to delete all at once.    some help.  is any lsp?
always thank you guys...
dbhunia
Try this.......
(defun c:Ren_Lay ( / Lay_name N str)
(vl-load-com)
(vlax-for layer (vla-get-layers (vla-get-activedocument (vlax-get-acad-object)))
	(setq Lay_name (vla-get-name layer))
	(setq N 1 str "")
	(repeat (strlen Lay_name)
		(setq val (substr Lay_name N 1))
		(if (or (<= 65 (ascii val) 90)(<= 97 (ascii val) 122)(<= 48 (ascii val) 57)(= 32 (ascii val)))(setq str (strcat str val)));;This will not Remove Space
		;(if (or (<= 65 (ascii val) 90)(<= 97 (ascii val) 122)(<= 48 (ascii val) 57))(setq str (strcat str val)));;This will Remove Space
		(setq N (1+ N))
	(vla-put-name layer str)
Debashis Bhunia
Co-Founder of Geometrifying Trigonometry(C)
________________________________________________
Walking is the First step of Running, Technique comes Next....
Kent1Cooper
Here's another way:
(vl-load-com)
(defun C:SLPC (/ layname fixed); = Strip Layer names of Punctuation Characters
    (setq
      layname (vla-get-name layer)
      fixed (vl-string-translate "~@#$%^&()_+{[}]'." "                 " layname)
        ; replace all such characters with spaces
    ); setq
    (while (wcmatch fixed "* *") (setq fixed (vl-string-subst "" " " fixed)))
      ; remove all spaces [original as well as just-substituted]
    (if
      (and
        (not (tblsearch "layer" fixed)); doesn't duplicate an existing Layer name
        (/= fixed ""); wasn't made of only such characters [reduced to nothing]
      ); and
      (vla-put-name layer fixed); rename it
    ); if
  ); vlax-for
  (princ)
); defun
That (if) part is important to avoid possible errors.
I did not include the hyphen  -  character among those to be removed, because it's an integral part of the [US] National CAD Standard way of naming Layers, but you can add it if you like, as long as you also add another space to the string of spaces to substitute.
Kent Cooper, AIA
nychoe1
thank you so much
