Remove first part and break from mtext
stijn.dedeckerM4Q3S
Message 1 of 11
stijn.dedeckerM4Q3S
i have a lisp that removes the first part of a mtext block,
Thats ok but is still leaves the \P
i cant figure it out?
(defun c:removefirstpart (/ ss ents ent text breakline-pos updated-text)
(setq ss (ssget "_X" '((0 . "MTEXT"))))
(if ss
(progn
(setq ents (sslength ss))
(repeat ents
(setq ent (ssname ss (setq ents (1- ents))))
(setq text (cdr (assoc 1 (entget ent))))
(setq breakline-pos (vl-string-search "\\P" text))
(setq updated-text (if breakline-pos
(substr text (1+ breakline-pos))
(entmod (subst (cons 1 updated-text) (assoc 1 (entget ent)) (entget ent)))
(princ "Text before breakline and breakline removed.")
(princ "No MText found.")
(princ)
Replies (10)
Message 2 of 11
paullimapa
change this:
to this:
(substr text (+ 3 breakline-pos))
Paul Li
IT Specialist
@The Office
Message 3 of 11
stijn.dedeckerM4Q3S
ok, this works but is still leaving a space at front so how to remove that also.
Message 4 of 11
paullimapa
Easy change + 3 to + 4
Paul Li
IT Specialist
@The Office
Message 5 of 11
stijn.dedeckerM4Q3S
i have tried that but then it removes also the first character of the second part.
My MTEXT looks like: example.JPG
Message 6 of 11
paullimapa
Share a dwg with your Mtext
Paul Li
IT Specialist
@The Office
Message 7 of 11
komondormrex
hey,
check this thread
Message 8 of 11
stijn.dedeckerM4Q3S
here is a example dwg
Message 9 of 11
paullimapa
so for example looking at these 3 lines of an MText (which I changed color to 3 to make it easier to see) before Removefirstpart is run:
The MText actually contains 2 locations of \\P:
Now after Removefirstpart runs this is how that MText looks like:
Now there's only 1 location of \\P left:
Then I run Removefirstpart one more time & now it looks like this:
There are no more \\P left:
I also don't see any spaces in front.
What are you trying to get at?
Paul Li
IT Specialist
@The Office
Message 10 of 11
stijn.dedeckerM4Q3S
i am sorry but i dont think there is a problem, i think it was just a problem with one specifc drawing
Message 11 of 11
paullimapa
Glad problem is solved…cheers!!!
Paul Li
IT Specialist
@The Office
