Remove a boundary from a hatch.. select objects problem
danglar
Message 1 of 12
danglar
I have a drawing with many "holes"(circles) in hatch and now I need to move all circles in a different places. After moving i have a boundaries remains in a hatch..
to remove it i use this little lisp:
(defun C:HR(/ gp) (setq gp (ssget))(command "-hatchedit" gp "r" ));remove boundary from hatch
but I have a problem when I need to select boundaries one by one..
Is it possible to select ALL boundaries in a one click in order to remove it?
Any help will be very appretiated
Replies (11)
Message 2 of 12
hmsilva
Hi apelbaum2014!
This is quick and dirty, and minimally tested, but it may get you started, and it will fail if outer boundary is also a CIRCLE.
I have a deadline to meet, so at the moment, I don't have much free time...
(vl-load-com)
(defun c:MHR (/ cen circle circles ent hnd i rad ss)
    (cond ((setq ss (ssget "_X" (list '(0 . "HATCH") (cons 410 (getvar 'ctab)))))
           (command "_.undo" "_G" "_.zoom" "_O" ss "")
           (repeat (setq i (sslength ss))
               (setq hnd     (ssname ss (setq i (1- i)))
                     ent     (entget hnd)
                     circles (vl-remove-if-not
                                 '(lambda (a)
                                      (and (= (car a) 330)
                                           (= (cdr (assoc 0 (entget (cdr a)))) "CIRCLE")
                                 ent
               (cond (circles
                      (command "-hatchedit" hnd "r")
                      (foreach x circles
                          (setq circle (entget (cdr x))
                                cen    (cdr (assoc 10 circle))
                                rad    (cdr (assoc 40 circle))
                          (command (list (+ rad (car cen)) (cadr cen)))
                      (command "")
           (command "_.zoom" "_P" "_.undo" "_E")
          (T
           (prompt "\Could not find any hatches... ")
    (princ)
) ;remove circle boundaries from hatch
Hope this helps,
Henrique
Message 3 of 12
danglar
Hi Henrique!
Thank you for the quick answer.
Unfortunaly, I don't now why, but I don't see any changes in my drawing after invoking MHR function. I mean hatch boundaries in circle form remanins in the drawing..
Message 4 of 12
hmsilva
Hi Henrique!
Hi apelbaum2014
Could you please post a sample dwg, with a before & after?
Henrique
Message 5 of 12
danglar
this is sample dwg. i work on acad 2013 sp3
Message 6 of 12
marko_ribar
Remarks removed after reinspecting...
Marko Ribar, d.i.a. (graduated engineer of architecture)
Message 7 of 12
hmsilva
Sorry apelbaum2014,
but as I had already said, I have a deadline to meet, so at the moment, I don't have much free time....
Attached is a dwg where I tested the code with no problem...
When I have some spare time, I'll see what I can do.
Henrique
Message 8 of 12
danglar
Thank you anyway Henrique.
It's intresting, but on your file MHR function works perfect and in a same time on my dwg not working at all...
Message 9 of 12
hmsilva
You're welcome, apelbaum2014
Another approach...Quick and dirty...
(defun c:MHR (/ cen cir i rad ss ss1)
    (cond ((and (princ "\nSelect hatch: ")
                (setq ss (ssget "_+.:E:S:L" '((0 . "HATCH") (-4 . ">") (91 . 1))))
                (princ "\nSelect CIRCLE boundaries to remove: ")
                (setq ss1 (ssget '((0 . "CIRCLE"))))
           (command "_.undo" "_G" "_.zoom" "_O" ss "" "_.ucs" "_W")
           (command "-hatchedit" (ssname ss 0) "r")
           (repeat (setq i (sslength ss1))
               (setq cir (entget (ssname ss1 (setq i (1- i))))
                     cen (cdr (assoc 10 cir))
                     rad (cdr (assoc 40 cir))
           (command "")
           (command "_.zoom" "_P" "_.ucs" "_P" "_.undo" "_E")
    (princ)
) ;remove boundary from hatch
Henrique
Message 10 of 12
danglar
Now it's works like a charm!
Thank you Henrique!
Message 11 of 12
hmsilva
Thank you Henrique!
Glad I could help
Henrique
Message 12 of 12
danglar
...a little improvment
(setq ss1 (ssget '((0 . "CIRCLE,LWPOLYLINE,SPLINE"))))
and Henrique's program now can works with almost all entities as hatch boundaries
