Reminder Popup
Reminder Popup
cvanriper
Reminder Popup
cvanriper
Several years ago, I had a LISP running on all my drafters computers to remind them to archive drawings if needed (before revisions are made and original files are overwritten). This was on a full version (2017, I think), not LT. It worked great, but we upgraded to 2021 and the lisp never migrated over and it was forgotten. The lisp required a block that was inserted into the template to work; The block was nothing more than a simple point, nothing noticeable. I would like to use this again and set up a new one to remind me to SAVE. I lost a lot of work yesterday because I clicked NO when it asked me if I wanted to save while I was closing a drawing and I "get in the zone" and sometimes forget to save periodically; ROOKIE MISTAKE! Please save the lectures. I have attached the LISP file and the block. The problem I am having is I cannot remember how to get it to work. I am using AutoCAD LT 2026 now.
CodeDing
@cvanriper ,
You don't need a block to accomplish something like that. Just add a dictionary to the DWG. Here, use these functions:
(defun ArchiveReminder-Set ( / )
  (dictadd
    (namedobjdict)
    "ARCHIVE_REMINDER"
    (entmakex
      '((0 . "DICTIONARY") (100 . "AcDbDictionary"))
(defun ArchiveReminder-Check ( / )
  (if (dictsearch (namedobjdict) "ARCHIVE_REMINDER")
    (alert "Reminder: Before editing this drawing,\nplease archive first if req'd")
(defun ArchiveReminder-Remove ( / d)
  (if (setq d (dictsearch (namedobjdict) "ARCHIVE_REMINDER"))
    (entdel (cdr (assoc -1 d)))
Best,
~DD
BlackBox_
I don't use LT, does it support SAVETIME for automatic/incremental saves?
If LT supports the UNDEFINE Command, in lieu of your block/dictionary reminder, you might consider using LISP (defun) to define a custom SAVE or QSAVE Command when LT first launches, that prompts you to archive first (yes/no) then does the SAVE(s) for you.
HTH
"How we think determines what we do, and what we do determines what we get."
Sincpac C3D ~ Autodesk Exchange Apps
Kent1Cooper
Does LT work with an acaddoc.lsp file?  [I'll let you research that in Help.]  That would be my suggestion for getting it to work -- it can run that AutoLisp routine [whether you use the Block or the Dictionary approach] upon opening every drawing.
Kent Cooper, AIA
CodeDing
Yes, just named different:
https://help.autodesk.com/view/ACDLT/2026/ENU/?guid=GUID-FDB4038D-1620-4A56-8824-D37729D42520
~DD
Kent1Cooper
So, @cvanriper, if you're using Acad LT but not for Mac, you should be able to just save your code directly into a file called acadltdoc.lsp [it doesn't even need to be in a separate file, or have a routine name], located in some place where everyone's AutoCAD knows to look for it, and that will be run every time anyone creates a new drawing or opens an existing one.  IF you already have such a file, you can just add that code into it.  Or keep it as the specific file you have, and put
(load "Archive Reminder")
into acadltdoc.lsp to have it run every time.
Kent Cooper, AIA
