Lisp does update table
thomas_huntFMPXR
thomas_huntFMPXR
any tips to correct this the table will not update with new link.
paullimapa
I see all kinds of errors after you enter 2
Can you share your lisp and share a dwg with datalinks using etransmit command?
Paul Li
IT Specialist
@The Office
thomas_huntFMPXR
(defun c:2 ( / linkname filepath range )
;; VARIABLES
(setq linkname "SystemDescription") ; Name of your data link
(setq newPath (getfiled "Select new Excel file" "" "xlsx" 0)) ; Full path to Excel file
(setq range "EXPORTTOCAD!B2:I16") ; Sheet name and range
;;MODIFYDATA LINK
(prompt (strcat "\n🔄 Modifying data link: " linkname))
(vl-cmdf "_-DATALINK" "Edit" linkname "Path" filepath "Format" "Range" range "")
;;REFRESH TABLES
(prompt "\n🔄 Refreshing linked tables...")
(command "_DATALINKUPDATE" "All" "K") ; "K" keeps formatting
(prompt "\n Excel link modified and tables updated.")
(princ)
Moshe-A
@thomas_huntFMPXR ,
Looks like the error arise from the above call that uses filepath as an argument but it is not defined in the function, maybe
it should be replaced with newPath?
Moshe
thomas_huntFMPXR
Still the same error
