Regions to Triangles
tidl_var_dette_min_gamle_email
I have a Region that I would like to convert to triangles.
If I use the MESHOPTIONS (Triangles) and explode the result, it's just what I want, but...
I would like to run it from AutoLISP, and it seems like MESHOPTIONS don't come with a possibility to skip the dialogbox i.e. -MESHOPTIONS.
Is there an other method or what to do?
pendean
Community Legend
Community Legend
Almost every option on that pop-up has a commandline setting, these are named in HELP for that command
https://help.autodesk.com/view/ACD/2023/ENU/index.html?guid=GUID-5D3AECBF-3097-4987-8C15-E587E2056CF...
Do you need more settings from that pop-up that do not have variables?
Also explore MESHSNOOTH and/or CONTOMESH to finish up.
HTH
Thanks for quick reply.
With the MESHSMOOTH or CONTOMESH I thought it would work, but for some reason (command-s "MESHSMOOTH" "l" "") won't.
