Regarding ; error: Visual LISP command document mismatch:
kerry_w_brown
Advisor Advisor
kerry_w_brown
I've posted a query here https://www.theswamp.org/index.php?topic=51409.msg565393#msg565393
as part of a discussion regarding the use of vlax-add-cmd  and ACRX_CMD_TRANSPARENT.
Anyone with any insight into the issue is welcome to chime in.
I'd particularly appreciate input from AutoDesk representatives (ADN )  as this is an ongoing problem and I'm unaware of a solution.
Kerry
// Called Kerry or kdub in my other life.
Everything will work just as you expect it to, unless your expectations are incorrect. ~ kdub
Sometimes the question is more important than the answer. ~ kdub
NZST UTC+12 : class keyThumper<T> : Lazy<T>;      another  Swamper
kerry_w_brown
BUMP.
kerry_w_brown
Is there any chance that 'someone' from AutoDesk could look at this issue please.
