Recursive construction of associated list
giuseppebeatrice222
giuseppebeatrice222
I read a very interesting forum in https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/recursive-assoc-and-subst/m-p/782358...
where Gile gave an optimum explanation and a solution to a question regarding the search of associated values and the substitution of values in nested  association lists.
Now I have a subsequente question, of how making from the scratch a nested association list, giving a key list and the final, nested value.
For example, if I want to assign to the variable al a nested association list  (setq al '(("GRP1" ("A" (2 (21 . "b")))))) is it possible to construct a recursive function of the tipe (MAKEORSUBST (list "GRP1" "A" 2) '(21 . "b"))
In addition, if I have fixed the preceding value for al and I want to add a new value (22 . "c") to the inner value (21 . "b") with the last key 2, can I obtain the result with a command of type (MAKEORSUBST (list "GRP1" "A" 2) '(22 . "c"))?
I have made numerous attempts to construct such a function on the basis of the functions provided by Gile in that forum, but with no results.
Please, can Gile himself or someone other give me a help?
Thanks in advance
ВeekeeCZ
OT. If you want to draw someone's attention you can use the @ character to do that: @_gile
Then he receives an email that he was mentioned by someone.
ronjonp
HERE is some code by master ElpanovEvgeniy.
Another thread HERE to flatten lists by master MP 🙂
_gile
The makeorsubst function also need an argument for the exisitng list/tree (nil if none)
(defun makeorsubst (keys val lst / sub)
  (cond
    ((null keys)
     (if (setq sub (assoc (car val) lst))
       (subst val sub lst)
       (cons val lst)
    ((setq sub (assoc (car keys) lst))
     (subst (cons (car keys)
		  (makeorsubst (cdr keys) val (cdr sub))
	    sub
	    lst
    (T
     (append
       (list (cons (car keys) (makeorsubst (cdr keys) val nil)))
       lst
_$ (setq tree (makeorsubst '("GRP1" "A" 2) '(21 . "b") nil))
_$ (setq tree (makeorsubst '("GRP1" "A" 2) '(22 . "c") tree))
(("GRP1" ("A" (2 (22 . "c") (21 . "b")))))
_$ (setq tree (makeorsubst '("GRP1" "A" 2) '(22 . "d") tree))
(("GRP1" ("A" (2 (22 . "d") (21 . "b")))))
_$ (setq tree (makeorsubst '("GRP1" "A" 3) '(31 . "a") tree))
(("GRP1" ("A" (3 (31 . "a")) (2 (22 . "d") (21 . "b")))))
Gilles Chanteau
GileCAD
GitHub
giuseppebeatrice222
Many many thanks Gile, it works very fine.
Your knowledge of recursion is fantastic.
