05:31 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hello everyone,
Can you help me with a lisp that after selecting some objects it will create a frame around it (like the example).
very similar to the lisp entitled "TEXTBOX" , but I want that after calling the lisp it will allow to select items, and the default offset will be 0.35mm.
The textbox lisp work like that:
It will be enabling the user to create a 2D polyline
rectangular frame around selected Text & MText objects, with a
user-defined offset. (The default is 0.35mm) .
And I want it to allow me to select either one single text and some entities.
Thank you,
Eyal
Here is the textbox lisp for indication:
;;----------------------------=={ Box Text }==--------------------------;;
;; This program performs in much the same way as the Express Tools' ;;
;; 'TCircle' command: enabling the user to create a 2D polyline ;;
;; rectangular frame around selected Text & MText objects, with a ;;
;; user-defined offset. ;;
;; Upon issuing the command syntax 'BT' at the AutoCAD command-line, ;;
;; the program first prompts the user to specify an offset factor ;;
;; for the text frame. This factor is multiplied by the text height ;;
;; for every selected text object to determine the offset of the ;;
;; rectangular frame from the text. At this prompt, the last used ;;
;; value is available as a default option. ;;
;; The program then prompts the user to make a selection of text ;;
;; and/or mtext objects. Following a valid selection, the program ;;
;; iterates over the selection and constructs a rectangular frame ;;
;; surrounding each object, offset by a distance determined by the ;;
;; given offset factor. The generated text box will inherit the ;;
;; basic properties of the enclosed text object (e.g. Layer, Linetype, ;;
;; Lineweight etc.). ;;
;; The program will also perform successfully with Text or MText ;;
;; defined in any construction plane, and under all UCS & view ;;
;; settings. ;;
;; Author: Lee Mac, Copyright © 2010 - www.lee-mac.com ;;
;; Version 1.2 - 2015-02-22 ;;
(defun c:bt ( / *error* def enx idx lst off sel )
(defun *error* ( msg )
(LM:endundo (LM:acdoc))
(if (not (wcmatch (strcase msg t) "*break,*cancel*,*exit*"))
(princ (strcat "\nError: " msg))
(princ)
(if (or (not (setq def (getenv "LMac\\boxtext-off")))
(not (setq def (distof def 2)))
(setenv "LMac\\boxtext-off" (rtos (setq def 0.35) 2 2))
(initget 4)
(if (setq off (getreal (strcat "\nSpecify offset factor <" (rtos def 2 2) ">: ")))
(setenv "LMac\\boxtext-off" (rtos off 2 2))
(setq off def)
(LM:startundo (LM:acdoc))
(if (setq sel (LM:ssget "\nSelect text or mtext <exit>: " '(((0 . "TEXT,MTEXT")))))
(repeat (setq idx (sslength sel))
(setq enx (entget (ssname sel (setq idx (1- idx))))
lst (text-box-off enx (* off (cdr (assoc 40 enx))))
(entmake
(append
(000 . "LWPOLYLINE")
(100 . "AcDbEntity")
(100 . "AcDbPolyline")
(090 . 4)
(070 . 1)
(LM:defaultprops enx)
(list (cons 038 (caddar lst)))
(mapcar '(lambda ( x ) (cons 10 x)) lst)
(list (assoc 210 enx))
(princ)
;; ssget - Lee Mac
;; A wrapper for the ssget function to permit the use of a custom selection prompt
;; msg - [str] selection prompt
;; arg - [lst] list of ssget arguments
(defun LM:ssget ( msg arg / sel )
(princ msg)
(setvar 'nomutt 1)
(setq sel (vl-catch-all-apply 'ssget arg))
(setvar 'nomutt 0)
(if (not (vl-catch-all-error-p sel)) sel)
;; Default Properties - Lee Mac
