really i need help
really i need help
abdulellah.alattab
Message 1 of 71
really i need help
abdulellah.alattab
Please i need lisp to do this task
Old topic link
https://forums.autodesk.com/tUntitled-13-2.png⁸5/visual-lisp-autolisp-and-general/call-for-help-cranking-polyline/td-p/13362612
Replies (70)
Message 21 of 71
Moshe-A
@abdulellah.alattab wrote:
Is it possible to add a button that prevents writing dimensions, and is it possible to rotate the rod during entry, and instead of the minimum of 1/5 and the maximum, is it possible to have more freedom so that we can use it for more purposes?
prevent dimensions? you do not add dimensions to bar?
rotate rod - what's that? you mean rotate the bar? you can do that after you draw it.
instead min / max - no problem
Message 22 of 71
Moshe-A
Addtional to pick axes can you add option , select two points
why? selecting the main 2 axis lines in one step is more easy, for the left / right axis you also can specify the distance?!
Message 23 of 71
abdulellah.alattab
For main field L1, CAN YOU ADD two retreat ratios, one for left side and one for right side in the seam main field L1. They only appear when one of the fields on the right or left is missing. Assuming the field on the right is missing, then I can change the value of the retreat ratio for the main field on the right side.
And add option to decide about hooked end length for filedes that is not showed
Message 24 of 71
abdulellah.alattab
Just a suggestion, nothing more, to make it easier to do the entry process when the axes are absent
Message 25 of 71
abdulellah.alattab
@Moshe-A  you do very effective job , are you civil enginner ?
Message 26 of 71
Moshe-A
@abdulellah.alattab ,
does that means that the main ratio is redundant?
post a new dwg how do you want to end the bar where left/side is not exist, how the hook will look?
Moshe
Message 27 of 71
abdulellah.alattab
Sir, this is what I mean. I have made it clear in the drawing. The first and second cases are all that concerns me. As for the rest of the cases, it will be an overflow of generosity from you, and be assured that you will accomplish something that everyone needs and will be used on a daily basis. Something similar to someone who provides a service to every engineer specialized in drawing concrete reinforcement.
Message 28 of 71
abdulellah.alattab
And can you rename lisp command to bentbar
Thank you from the depth of my heart
Message 29 of 71
Moshe-A
So the left field is totally redundant ?
S-L  & S-R are varies?
the hook can be shorter then bar depth?
in case-2 the bar  extend (S-R + Retreat 3) ?
you want to drop dimensions at all?
Message 30 of 71
abdulellah.alattab
So the left field is totally redundant ? No ,  I want it too
S-L  & S-R are varies? Yes
the hook can be shorter then bar depth? Yes  , shorter or longer than depth
in case-2 the bar  extend (S-R + Retreat 3) ? Yes ( left or rigth  field length  L1 OR L2 mesuered from after S-R or S-L  , (  S-R or S-L ) never divied by factor it is addtional length
you want to drop dimensions at all? Yes , with addtional option To prevent drawing dimensions if i want , dimscale can be lower than 1
Message 31 of 71
abdulellah.alattab
Pick points for main field is better to work at any angle in model space
Message 32 of 71
Moshe-A
if you also want the left field then post a pic with full full version + how do you want dimensions, layers?
i am requesting this cause this is already a huge program and any addition/changes can make is grow and it will take time to accomplish
but i hope 🙏 you'll visit here each day to see it finished.
Moshe
Message 33 of 71
abdulellah.alattab
Thank you sir , For the fields, the same program as before with the suggested additions. I will visit the post every day. Thank you for your cooperation.
Message 34 of 71
Moshe-A
@abdulellah.alattab hi,
i start working on it and i expect to post it in 2-3 days, so keep in touch here 😀
Message 35 of 71
abdulellah.alattab
Thank you sir, work according to your available time
Message 36 of 71
Moshe-A
finally i got it 😀
This version complies with all your request (case-1 through case-5) although i can not be 100% sure that all cases works, you will have check.
running instructions:
after loading reinforce.vlx invoke BAR1 command.
Main field 1
Specify Axes < let you specifies the main axes lines, you start with the left line and angle (-90 to first) to the second (system will copy that line automatically) the angle of the first axis can be any angle  but the axes lines must be parallels with exact lengths.
Select Main Axes < let you select existing axes lines. the selected lines should grow from bottom to top and the first should be on the left side. otherwise you might get upside bar.
Length1 + Bar Angle are always grey and they shows the Main Axis lines distance and angle.
Retreat Ratio L-1 + Retreat R-1  works inside Main Axes Field.
Left/Right fields L2 / L3
Additional  S-L + Additional R-L  extend length
Left/Right Hook   you already know
Length 2 / Length 3  is specified only by length only.
Retreat Ratio 2 / Retreat Ratio 3  you already know
Bend Depth / Bend Angle   you already know
set bend Depth to a negative value in order to get upside bar 😀
in properties a new switch Add dimensions for adding texts to bar segments
at the left bottom a new switch delete axes line turn this on if you want to delete axes lines.
switches \ toggles
each option has a toggle on its left side, enable it to activate the option
if switches Length2 / Length3 is enables, Retreat Ratio 2 / Retreat Ratio 3 are disabled and vice versa (meaning you can not have hook and extended  length together but you can use Additional S-L / S-R.
enjoy
Moshe
Message 37 of 71
abdulellah.alattab
@Moshe-A
Super ,I thank the hands that completed the task.
Thank you, you have overwhelmed us with your generosity.
Message 38 of 71
Moshe-A
@abdulellah.alattab
Thank you for that  😀
i have already thoughts for fine tunings and even some improvements.
i would like to see a video running it on real working drawing?!
Can you share with us your real thoughts when you first came to this discussion group, Did you thought you will get such a help?
i was very impressed from your accurate detailed explanations (including the drawing picture)
ps:
forgot to mention the Retreat edit boxes are not limited now but of course must be less then 1.
correction to this....
instead "Retreat Ratio 2 / Retreat Ratio 3"  i meant Left/Right Hook  sorry 😂
"if switches Length2 / Length3 is enables, Retreat Ratio 2 / Retreat Ratio 3 are disabled and vice versa (meaning you can not have hook and extended  length together but you can use Additional S-L / S-R"
Moshe
Message 39 of 71
abdulellah.alattab
Thank you sir, great and very smart effort, especially the idea of ​​the method of choosing the axes to guide the drawing, it resembles a steering wheel, I still have a problem that I hope you look into because we usually work considering that one unit in AutoCAD is equivalent to one meter in nature, and I would like the input and drawing values ​​to accept decimal values ​​less than zero 0.0001, and I have added my notes resulting from the experience of the second version
Message 40 of 71
Moshe-A
OK i will be fixing these this week, keep visiting here every day 🙏
